Results 1 to 7 of 7
    May 2010
    Post Humidity Assisted Thermostat - Recommendation
    I am considering having my thermostat replaced with a "humidity assisted thermostat".
    My definition of an energy assisted thermostat is a thermostat which turns on the AC/HP according to temperature (only) and runs until the temperature is at the desired level. If the humidity set point is lower than the actual humidity, then the AC/HP will continue to run until the humidity is within range or the temperature is X degrees lower than the set point.
    I have read the manual for the Honeywell TH8321 which will lower the temperature by 3 degrees if the humidity criteria is not met. I wonder if 3 degrees is too much.
    I would like feedback from anyone who has experience with any models of "humidity assisted thermostats".
    Thanks,
    Dave
    Do you have a variable speed blower?
    The temp drop is up to 3. It can also be restricted to 1, or 2.
    May 2010
    Post
    No.
    May 2010
    Smile
    Thanks, beenthere. I only have user's manual for the TH8321. I assume that data is in the installer's manual. The ability to restrict the temperature drop is a BIG plus.
    Yes, that is in the install manuals.
    May 2010
    Do any of the Honeywell's have energy monitoring capabilities? One of the quotes I'm reviewing calls for a new Honeywell (not sure of model) but I'd like to be able to see how many hours the 2-stage furnace is running in each mode, likewise for the a/c.
Tags for this Thread
