    Nov 2011
    expansion valve problem
    We have a situation with a water to water heat pump.
    If the bulb of the expansion valve is stick to the pipe , after 30 sec is closing the flow and the pressure goes up (at 20 C is reaching 2.5 mpa)
    If we remove it from the pipe, and is not regulating the flow, the heat pumps works perfect.
    It is a thermal expansion valve from Emerson ....
    las vegas
    are you sure everything is positioned properly & your charge is
    correct
    Dec 2011
    Is it a water furnace? They had a bad batch of TXV's that when out. It sounds like the TXV has lost some of its head charge.
