Results 1 to 6 of 6
    villalba,p,r
    hi'' guys" I have a chiller York model ycaso440 compressor DXS45LASA46/50 Here is the problem,the compressor has a strong noise,like snoring!! Everytime I change the oil I fine Esmeril but the sound continues. this is the display reading''' 66=fla oil=214psig DP=235psig SP=58psig suct sheat=11.0f DSCH SHEAT=70F COMPRESSOR STEP=53 The noise is very strong in the compressor. Should I change it? or Should I wait until it breaks down? this type of compressor cannot be repair,it must be replace. But I would like your opinion,or idea THANK
    maybe bearing problem
    juan clavell santiago
    BR,LA
    quote orland25 "Everytime I change the oil"
    Question: why are you changing the oil
    you could do an oil analysis to get your answers, but it wont tell you anything if you just replaced the oil.
    [Edited by joeywpittman on 06-22-2006 at 09:07 PM]
    villalba,p,r
    excuse" I change the oil filter, I do oil analysis but in the analysis fine esmeril. In the oil filter section I fine esmeril.
    Western Wa
    11 degrees suction SH ?
    Never touched a York screw, but isn't that a little dry?
    God Bless our Veterans
    God Bless the USA
    chicago
    you can change the bearings just keep all the shim packs on the same side they came out of. The bearing are the same as FAG bearings you can get the at a local bearing shop, be very clean!!!!!
