Results 14 to 15 of 15
    Nov 2010
    Central Florida
    Thanks Lynn, very helpful feedback as usual.
    In my case I think the pad and the ground might be a factor as well (Foam filled concrete hurricane pad on sand instead of a poured pad)
    Soupcxan, some curiosity questions:
    - What style of pad do you have?
    - What is the composition of the ground on your property (sand, dirt, gravel)
    - Where/how is your lineset running into the home?
    Aug 2011
    Confused
    Quote Originally Posted by SonicExplorer View Post
    poured pads transfer noise,i use a duralight pad,polymar,with rib backing,on dirt!
