Results 1 to 13 of 15
    Fan or compressor making oscillating humming noise
    We have a 4 ton York heat pump outside our bedroom. Since it has started warming up, the AC has been running and there is some noise coming into the house. The noise is sort of a humming, but the pitch oscillates back and forth every second or two, and then sometimes stays constant for a little bit, then starts oscillating again, sort of like the vibration is coming into phase and then drifting out of phase.
    I don't hear the noise when it's just the air handler running. The AC has always made noise but I don't remember it being like this last year, although it's hard to say. Can you give me any ideas what might be causing this?
    I am a light sleeper and normally I like the constant drone of an AC to help me stay asleep. However this variable noise is making it hard for me to fall asleep. My wife doesn't hear it but I do.
    I am not looking for DIY info, just some ideas so I can tell the tech what to look for. Odds are the tech might not hear the noise like I do, it is subtle but annoying.
    Apr 2010
    Southeast
    Too many parts it could be to say without looking at it. Or in your case hearing it.
    Kind of hard for us to say what could be causing it. Since we can't hear it either.
    A tech on site would have a much better chance of hearing it, then us just guessing. Without checking anything else.
    Give him the same description you gave us.
    May 2010
    Florida
    Just a possibilty but sometimes when the service cover is not tight it will do that.
    Aug 2011
    Did you ever get an answer to your oscillating fan noise issue? Mine is doing the same thing.
    Nov 2008
    SW Florida
    I just snugged up every screw on the outside of the unit. They are sheet metal screws, don't strip the metal out, that took care of it.
    Jul 2011
    Thumbs up
    Quote Originally Posted by Gulfside View Post
    that's why you make the big $$$$$$$$$$$$$
    Quote Originally Posted by aliceme View Post
    Not really, I think tightening the screws helped some but the noise is still mostly there.
    Aug 2011
    Just fyi...I took off the cover for the intake vent and lined it with weatherproofing strip (the kind used around a door). Noise is gone.
    What part do you mean by "intake vent"? My compressor pulls air in over all the coils on the 4 sides and vents it out through the fan in the top. Maybe I need to put some weather stripping where the fan panel meets the box (e.g. the four corners of the top of the box)?
    Aug 2011
    Sorry for not being clear. I mean the vent in the bedroom where I sleep, not a vent on the actual unit. I took off the small (6x10?) vent that pulls air out of the room when the AC/ fan is running, put weather stripping on it, and put it back on. No more noise. It was an inconsistent whirring sound, so I wasn't expecting this to work, but it did. Good luck!
    Nov 2010
    Central Florida
    I've got the exact same droning hum problem, but haven't been able to figure it out yet either.
    Jul 2002
    Yuma, AZ
    Each motor and the compressor may generate a regular sound pattern with different frequecies. These sounds interfer with one another resulting in the increasing loudness and decreasing loudness pattern that you are experiencing.
    The physics is explained at http://www.physicsclassroom.com/Class/waves/u10l3c.cfm
    The principle of superposition is sometimes stated as follows:
    When two waves interfere, the resulting displacement of the medium at any location is the algebraic sum of the displacements of the individual waves at that same location.
    The solution: Isolation of one of the motors or the compressor (often with rubber) may help if one of the sound sources is driving something else to produce a sound (like a loose panel). Pressing on various components with a rubber tipped stick may help locate the source of the sound. Because of moving parts and electrical dangers, this may be best done by a pro.
    "I have never let my schooling interfere with my education."
    Mark Twain
    NEVER STOP LEARNING.
