Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 54
  1. #40
    Aug 2010
    Memphis
    If everybody is so conserned with tank trash why don't you just run the refrigerant through a dryer when you put it back in?
  2. #41
    Jun 2009
    NYC
    Thumbs up
    Quote Originally Posted by mrllyonsden View Post
    As far as I am concerned, recovery tanks are for disposal only. I have never re-used refrigerant from a recovery cylinder, virgin gas only back into a system. Thats my view, If you recovered the refrigerant, it was because of a problem with the system right?
    same here, only virgin back into the system..
  3. #42
    Dec 2009
    Southern US
    How about Devils advocate!
    Quote Originally Posted by keviekev70 View Post
    Ok lets say you just pulled a charge and replaced a stopped up dryer that was found to have a major temp drop across it. You vacummed and weighed in a virgin charge.
    Now you start the unit and OH H#LL the orifice header tubes are stopped up to. Would be almost impossible to have diagnosed prior due to the drier restriction. So you recover the charge you just put in.
    After changing the orifice header what you gonna do????
    I'm good at making things cold...You can ask my first two wives!
  4. #43
    Jun 2009
    NYC
    Wink
    Quote Originally Posted by BKS60 View Post
    In this case I will recycle the refrigerant back to the system...But generally speaking if I recover less than 30lb of used refrigerant I tend not to recycle. I prefer to use virgin gas rather than putting back possable contaminated gas back into the system even though the F/D's are replaced.
  5. #44
    Jan 2005
    Houston TX
    Long running Thread
    One company I worked for had the big 1000# tanks with the liquid dip tube. We simply used a 3 or 4 core replaceable shell with valves on the inlet and outlet. It was piped to the base of the tank for liquid recovery push / pull. When it came time to return the refrigerant to the vessel it went through a new set of clean-up cores before it went back in the chiller. If the situation was warranted all the valves were removed and (bite my tongue ) R-123 was circulated through the tank. The top refrigerant level gauge port (float) was removed and a spray header was installed in it's place to spray all down the sides of the tank to the bottom and returned through replaceable cores to a refrigerant pump and kept circulating until the delta "P" across the cores was negligible. As bad as R-123 maybe it is one excellent cleaner. The refrigerant was then pumped into a holding cylinder, the R-123 liquid and vapor was pulled via a recovery system to micron range. The system was charged with dry nitrogen to 10 CFH while all connections were removed. The drum was left with a 5# holding charge of dry nitrogen until the next use, when it was evacuated. Any of the labor cost 5 hours per cylinder was added to the job costing. The also had air compressor tanks with 10' blind flanges 6" from the bottom, welded on the side for reaching in and cleaning. Even with these avail options there were times when you got dirty tanks on the job delivered right in front of the customer. That's always a hard one to explain-GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
  6. #45
    Mar 2010
    Morgan Hill Ca.
    Sooooooo how are you determining whether or not you have the proper oil charge if you throw away all of the old, oil laden refrigerant?
    Your practices are only helping accounts payable in making more money for the company, your not doing any other good at all, period. Just my opinion...
    GT
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
  7. #46
    Not in Iran
    Quote Originally Posted by GT Jets View Post
    GT
    i agree with u
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
  8. #47
    ottawa canada
    So lets say you have a 1000ton chiller on R123 and for the sake of argument it has 1500lbs in it . Its purring like a kitten no oil loss no issues . It develops a minor leak at the evap to liquid line flange . The only way to fix it it to pull the charge .
    I can hear the phone call now .
    Hello Mr Customer . I have that repair quote for you chiller it of course includes a totally new refrigerant charge just because were removing it and we at Hack Air only use virgin refrigerant . You quote will be 60 G's .......When can we start ?????????
    Silence is golden as they say !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. #48
    Jan 2011
    Southeast, Michigan
    I oversee a facility for a Major Manufacturer and if my folks didn't recycle and we reported that level of use, their environmental folks would have a ...
    ... and they would find a new FM.
    Klaus
    Walbridge FM
    "I owe it all to little chocolate donuts." John Belushi (1-24-49 to 3-5-82)
  10. #49
    Jun 2009
    NYC
    GT
    I'm a little residential, light commercial tech, not a big chiller guy, we are not in the business to loose money, if the cost of refrigerant is less than getting a call back or not getting to the next call, so virgin refrigerant is the way to go. What the office does is none of my business.
  11. #50
    Dec 2009
    Southern US
    You may want to go to the top of the page and look at the forum this is under. 100, 500, 2000lbs and more are normal charges.
  12. #51
    Jun 2009
    NYC
    Smile
    Quote Originally Posted by graham View Post
    graham at least my phone's ringing and this when I sub it out to you...lolzz
  13. #52
    Dec 2009
    Southern US
    keviekev70
    You may want to slow down and read the quote from graham you quoted!
    Under your self stated beliefs I doubt your phone would be ringing and I an SURE you would not be able to subcontract him.
