    Indiana
    contact info for Macurco
    have a CO detector FLASHING an amber light. ran unit threw test and nothing came up and light is back to solid green.
    Instructions say nothing about flashing. Would like to give them a call but number is out of order.
    model: CM-21A
    make : Macurco
    it has 3M printed on the cover
    Jun 2006
    New Jersey
    Quote Originally Posted by yellowirenut View Post
    model: CM-21A
    make : Macurco
    They can be a pain. If it's flashing amber, then it's a error. Mostly caused by a voltage problem to the sensor. If your 24v is good and you still have one erroring out, then just replace it.
    Normally it's a sensor going bad.
    Indiana
    thanks for the info...thing is 10 months old. If it does it again i will change it out.
    Jun 2006
    New Jersey
    How is the voltage to it? They are very picking with voltage.....and you find alot installed with very long undersized wire.
    Indiana
    just one sensor..on its own transformer 18 ga wire less than 40ft. Wired so an exhaust fan contractor is pulled in on ether high CO or t-stat call for cool.
    Jun 2006
    New Jersey
    So the two reds are directly wired to your transformer, with no other connections to you fan?
    Reason I ask....is sometimes erratic voltage doesn't happen until the sensor actually senses CO for fan activation, under certain wiring situations.
    You can check it by activating the CO sensor with a CO kit. We use the kit from Macurco.
