    May 2010
    New jeresey
    Cool decreased fan motor amperage
    On my air handler, will i get lower than normal amperage readings, if my return air damper shuts or will the motor struggle trying to pull air back causing higher amperage.
    Nov 2002
    NJ - WORK IN NYC AREA
    Hmm
    If it's a centrifical fan, the less air you move the lower the amperage.
    "My hands are for sale"
    Jul 2009
    In a mechanical room....
    Put your amp meter on motor and remove cover, but yeah most of the time the amps will drop
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    May 2010
    New jeresey
    yah thanks for the info
    Southeastern Pa
    Quote Originally Posted by icedr024 View Post
    When you block off the return air (the damper closes) you are "starving" a typical blower -type fan for air. Less air is available, less work is being done, lower amps will flow to do that lesser amount of work.
