Results 1 to 8 of 8
    Earth
    Does anyone have any info on the trouble shooting sequence for a trane variable speed, A/C cond unit. Its a TTS. Without some kind of operational theory, it's like threading a needle blindfolded.
    Are you asking about a 2 speed compressor?
    Earth
    No it's a true variable speed. I think it's a DC compressor with a inverter speed control. Not something you come across everyday
    Dec 2001
    Woodstock Ga
    is that a 1500 or something like that? i remember @ 1990 trane had a vs comp in the "xv1500"?
    In the land of the blind the one eyed man is King! semper fi
    Earth
    Then, they stopped making it in 95.
    Hell Hole Swamp
    I have a customer with 3 of those, no idea on troubleshooting the compressor except..... if its broke, replace it, Im sure the replacement price on the compressor or the controls is outrageous, if they are even available
    Jun 2001
    Louisville, KY
    They're available, and you are correct on the pricing...better to replace than to repair. Since most techs haven't been to any training on these beasts since 1993, you'll end up doing more part changing than troubleshooting. I'd recommend selling a new system unless you can get your hands on the troubleshooting guide. It's available through your local residential distributor.
    Apr 2003
    Iowa
    Agreed....you CAN'T trouble shoot that thing without the big thick manual, you just can't.
    I have worked on a couple. Changed out one because the bridge rectifier(converts a/c to d/c) shorted and a/c power took the compressor out. Worst part, the damn unit was sooooooo big I had to pop the top and climb in to troubleshoot the compressor.
    There are 3 ways to do anything in life; Good, Fast, Slow: You can pick any 2.
