Results 1 to 12 of 12
    8th grade
    COPELAND TANDEM COMPRESSORS
    I was told by copeland that if you replace one tandem compressor then you must replace both!
    What is the reason for this?
    thanx
    frank
    I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
    YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
    Mar 2009
    Mid-Mo
    All the people I have talked to that said that were salesmen. I have changed many single compressors in a tandem circuit.
    What is the reason for changing the compressor? Burnout? Acid??
    8th grade
    mid mo
    are you from missouri????????????????????????????
    I do not think it is a burnout???
    that is why I ask
    ofcourse any krap from the bad compressor can get in the new one!!!!!!!!!!!!!!!
    i remember copeland rep telling me some other reason a few years back but can not remember
    Mar 2009
    Mid-Mo
    Ya I live down at the Lake of the Ozarks and I work down at Fort Leonard Wood.
    You do have to be aware of the piping, I know McQuay ended up changing some of the piping of their tandem scrolls from from a 3 pipe to a 2 pipe with a oil crossover. Make sure you end up ordering all the stuff you need.
    8th grade
    i spent the last year working at ft wood
    bct3 barracks!!!!!!!!!!!!!!!!!!!!
    weitz/wattz
    I am going to just replace both compressors
    i just wanted to know what to tell the customers
    Quote Originally Posted by ryan1088 View Post
    Mar 2009
    Mid-Mo
    Small world. I hear the funding is in the works to build another BCT.
    We were hoping to get some training on those new units over there before we just get a no a/c call on them.
    8th grade
    i wired up installed started up piped up and commissioned every piece of equipment there!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    just call me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
    same with cdc!!!
    we are also doing some warehouse soon
    frank
    we have done it both ways. Never seemed to matter but we changed the oil on the good compressor besides changing out the bad. Both ways we have never had a problem.
    Jul 2009
    In a mechanical room....
    IN the old days we use to replace both for many reasons, metal shavings, acid, burn out, it can be summed up by the phrase cross contamination. I replaced a trane 3d 15 ton comp in a tandy and one month later the old compressor died and then had to replace old comp that had burnt up and now contaminated the new compressor it's a vicious cycle. We did not loose either new comps after that. In both instances the proper procedure's and precautions were taken to protect the compressors suction line dryers, new oil etc but still if you can why not replace em both it may save you a head ache down the road.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by supertek65 View Post
    thanx
    frank
    So that the guy who told you that can take his ol' lady to Maui on their next vacation.............
    Mar 2009
    Mid-Mo
    same with cdc!!!
    frank
    Sweet, I will take you up on that. Something will happen and of course it'll be 100 outside. Just how things go!
    Outside The Motor City
    The safe bet is to replace both or leave it open to the customer this way.
    The compressor went bad for a reason, for which I do not know why, and until I replace it and see what is happening in the system further action may be required.
    NO Brains NO Headaches
