Results 1 to 13 of 15
Thread: Seen This?????
    Colorado flatland native
    http://content.honeywell.com/yourhom...ionpro8000.asp
    I'm installing my first one today. Can't wait.
    Walter Matthau
    SE Michigan
    Very nice spotts! Havent put one in yet. Do they require a common? Are you installing it in res. or comm. I bet there pricy also. Peace.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Thumbs up
    high tech time to get out of the stoneage
    You kids would like something like this. Don't sell it to any old people. I tried to program it on the vitural thermostat and I found it too be complicated. I guess I'm a die heart White Rodgers man.
    Apr 2001
    san jose,ca.
    You got that right benncool,make it simple, i use w/r stats to.Those things are to complecated for me.When i install those digitals i tell the customer to program it them selfs.
    Hell i can`t even get the remote for the tv to work for me.
    Apr 2002
    Dallas TX
    If you guys can use an ATM then you can program one of these. You can program one on the website and although it is a simple program some people have done it in under 15 secodns including time and date. Personal best is around 45 seconds.
    To answer some of the question:
    You can run it 5 wire with a common or off of batteries.
    It is heat pump as well as Gas single stage Electric single stage gas 2 stage electric 2 stage heat pump 2 stage gas 3 stage elec 2 stage 2 stage or single stage cool. Hydronic heat or run millivolts through it. It can be either programmable or nonprogrammable. If you lose power the batter inside keeps the time and date as well as program for up to 10 years.
    The only thing this stat does not do that I have seen is line voltage. It is a 1 stat fits 98%. They also will have one that is RF that comes out later this year.
    Apr 2002
    Dallas TX
    Try this web site instead. http://www.hotfreshcool.com
    Sep 2003
    western canada
    Not too bad. Wish it had system auto change over.
    work to live not live to work
    Dec 2001
    We have programable stats at the cottages the only thing the residents use on them is the hold feature I have yet to see one of them programed.
    Apr 2002
    Dallas TX
    ""It does everything but line voltage"
    It does auto change over.
    Apr 2001
    san jose,ca.
    Will it tell me when my hens lay eggs?
    Apr 2002
    Dallas TX
    Ofcourse.
    It tells you when the humidifier pads need to be changed as well as the filter and the UV light.
    Apr 2001
    san jose,ca.
    If it only could tell me when my wife is going to start talking so i could turn my hearing aids off.
