Results 14 to 23 of 23
    Apr 2010
    CANTON OHIO
    if it keeps running its low on gas. you can still git 502. but the cost is out of hand. you might be better off to change it to mp39 or 404. but make sure what gas will blend with your composer oil. and you will have to change the cap tube. git all numbers off the composer call a ref. store. ask them what freon will mix w/composer oil. they look up the numbers and tell you. im glad i was a help to you. leave a little slack in that belt. it"ll last longer and will ease the tenchen on the gears in the gear box . good luck sell more ice cream. its hard to sell in the winter.
    Apr 2010
    CANTON OHIO
    herve you wouldnt be bothering me. to ask any question. i had them when i started out. any way i own the company. now i watch people work. and fix their mistakes. any time you have a question you ask if i cant answer it i"ll know someone who can. thanks good luck. and if you need hard to git parts or answers. hollar
    May 2010
    Electrofreeze CS2 - 2 Part Question, Need Advise!
    Hi! I'm new here and very glad to find this forum with the same CS2 that I have as the topic.
    This is a 2 part question.
    1 - a couple of months ago, the left side was working perfectly and that same day, it just stopped freezing. I found this out when liquid came out as I was making a smoothie, ouch! It was fine all day and then just stopped. Does anyone know what could be wrong? It turns on and you hear and feel the air, but the actual freezing never kicks in anymore. I called the local service guy and they want to charge $$$ just to look at it and telling me it could range from a thermostat to the actual compressor.
    2. Since one side is not working, I was strictly using the right side and just this morning, I came in to a loud screeching noise . Apparently the mix was frozen hard inside the barrel and that was causing the beater to screech inside. The mix on the top hopper was very icy. I did turn it to night mode and I assumed this brought the temperature down not up. There are 2 adjustment dials when I take off the front panel. I had it at .5 seconds before and now moved it to 10 seconds. I am not sure what the other dial is for.
    Lastly the machine is located in the corner of a wall. There is room for ventilation but I would not be able to get to back panel nor the right panel. I do have access to the left panel.
    Please advise!!
    Thank you!!!
    Felipe
    Apr 2010
    CANTON OHIO
    if this is a two or three difrent. flavor mach. you might have copeland compressers or tin can type. 1stept. put your manfolds on it. see if you have gas could be an r22 mp39 or 502 thats an old gas . turn mach on check presure. sounds like a pluged cap tube.or you could have lost the valves in the compressor.maybe if you call me we can try to walk it over the phone. 1 330 316 2826 george. this way i can ask ? s as you being my eyes. its probley simple but im not their. the cap tube is a little shaped like a bullet close to the tub under the meatel cover. see if you have a frst on it thats good or just put your hand around it to see if you feal like a blast of cold you"ll feal the fealing you wont git shocked or any thing also check the presure swich the one that gives you your differnt temps under the bottom cover so blk or white box their under the drip tray. they do go bad, you need a stat to make temps.
    Apr 2010
    CANTON OHIO
    i know service calls cost. its the flat rate that bites. but you got to think their know refrig. they have the tools most of them have to be trained thats why its costly. like i said if i can help your know stranger to a telphone.3303162826
    Denver , Co.
    End user
    Would it be safe to say this is end user helping end user ?? lol
    Outlaw guns? only outlaws will have guns
    Those who live by the sword are SHOT by us who don't.
    Jan 2013
    Hi! I have an urgent question. The left hopper on my 2 flavor electrofreeze machine stopped working. The left side is working fine. On the right, it's freezing and dispensing correctly. however, the (top) hopper is not cooling. What could be wrong? How do I fix it? Thank you!
    Denver , Co.
    Electro Freeze
    Quote Originally Posted by AustinFroYo View Post
    Well if its a CMT 30 with dual Compressors , Remember that Left side cools the Cabinet also , Check your Refrigerant level , check the Mxv , Sol. valve , , etc. etc. if its more than 10 years old , i would suspect the Compressor just from experience , but make sure you check everything else first, 18 20 psi is what your compressor should be pulling down to.
    Jan 2013
    Quote Originally Posted by IceVicious View Post
    I've never heard "cabinet" be used with this machine. What part does that respresent? Please don't give up on me! I'm a single female very small business owner here with 0 contacts and this is my only machine. The machine is only about 4 years old. The left side is still doing exactly what it needs. And the rigt appeared to be. It was freezing the fro yo and dispensing it just fine. It wasn't until later in the day that I realized the top hopper wasn't chilled at all. I tried turning the machine off, night mode, day, etc. This has happened once or twice before, but just started working again the next day after leaving in night mode. This time, no luck. Can you narrow it down any better? How do I check the things you mentioned? I may need guidance, but more than willing to get dirty and do everything I can to fix the problem!
    Denver , Co.
    Other than checking your mix and for air leaks you need to get a hold of a Refrigeration Tech. Im sorry unless your in Colorado i cant really help any further
    IceV
Quality Home Comfort Awards
