Results 1 to 4 of 4
    Mar 2002
    I need a schematic for this unit.. any help
    Lennox Mod# HP765V31L SER#5172M03091
    What I did was remove this unit and put in a carrier but the heat pump had an xmfer in it and i did not look at the print on old unit.
    Jan 2003
    Beaufort, SC
    Lake is an exmer a transformer? if so that is where your RC and Rh terminals on the stat come in. did you replace just the outdoor?
    Mar 2002
    Yeah just the out door section, it has a carrier 90 plus inside but someone installed a heat relay and a cooling relay to the furnace, it is a true nightmare. I have to go back on this tomorrow will take pics of it. I just thought i would see where they used the wires for my common and so on.
    Jan 2003
    Beaufort, SC
    They probably wired it similar to a coleman mobile home. Jusst trace it out you'll figure it out.
