Results 1 to 13 of 13
04-29-2010, 06:44 PM #1
- Nov 2008
- DFW,TX
- 1,915
cfm measurements with Digital Anemometer?
Ok so i was looking at buying one of these and want to know some that are good some to stay away from and also do tese all have issues with needing professional expensive calibration?
I would like one that actually has CFM on it so i didnt have to use a calc from FPM to cfm..
Extech CFM/CMM Thermo-Anemometer looks like a decent one but may need calibration , which ones do not? these things range from $50-600 buck all being basic with just wind speed all the way up to multi function.. is this the best way to get cfm at supply's and such so i can get total cfm for the house and balance the duct cfm output?
input on what you are using, have used and some good and bad on the ones out there?
04-29-2010, 06:54 PM #2
- Nov 2008
- DFW,TX
- 1,915
BTW i have a testo 510 manometer and I ordered a 18inch pitot tube that you can PUT INTO DUCT , what exactly does this measure, im not talking about the static tips but the big pitot metal tube, is this a way to measure cfm somehow?
04-29-2010, 06:58 PM #3Gotta have the right tool for the job!
Where is all the stuff MADE IN THE USA?
"Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
04-29-2010, 07:07 PM #4
I have had good success with a Testo 416 to measure both system CFM as well as branch run (metal) volumes.
So easy to use a kid can do it.
Ed J
04-29-2010, 07:12 PM #5
- Jan 2005
- Akron
- 790
Being in Texas, you need a big anemometer 417.. No joking. You guys deal with a lot of flex in the attic. A large vane is used to measure airflow at the returns. The 417 will allow you to measure at the grill and calculate the CFM directly even with multiple grills. It is easy to use.
JLB- Co Owner TruTech Tools Inc.
04-29-2010, 07:16 PM #6
how do you do it? I havnt seen you around in a while and now there is a air flow question and here you are lol. Nice to see you again .
Since were in this topic how does this tool work? Never seen it.
How does it compare to a hot wire? I know you have to factor in for air density with the hot wire but never knew how to do it.
to the op not to steal your post, I believe these questions related to your question..Gotta have the right tool for the job!
04-29-2010, 08:12 PM #7
- Nov 2008
- DFW,TX
- 1,915
05-02-2010, 11:58 AM #8
05-02-2010, 01:58 PM #9
- Mar 2008
- mesa arizona
- 309
hey
hey fcs whats the price of that meter where u gte it at ??/
05-02-2010, 03:32 PM #10
Depends on what you are going to do with the instrument. If you are going to get into air balancing, then you will have to send it off for that expensive calibration you mention. I've been on jobs where I had to show proof that my meter had been calibrated in the last 6 months, but most are one year. I have TSI's 8386 and their 8355 as a backup. I also have Testo's 416 mini-vane and their 410 pocket meter. All four have given me good service, although all but the 8386 were purchased off of Ebay.
05-02-2010, 03:35 PM #11
- Mar 2008
- mesa arizona
- 309
hey
nah im svc tech commericIAL... JUST WANNA GET A BASIC TOOOL TO MEASURE CFM
05-02-2010, 04:02 PM #12
I'm a commercial tech myself. I measure airflow for diagnostics, not trying to air balance. I use a dual input manometer and tachometer to verify equipment airflow. Then if needed I'll use an anemometer at the diffuser to get a rough estimate. I'll look up a similar style diffuser in Hart and Cooley's book to get my net free area to program into my anemometer and then take about 5 quick reading to average my cfm. It works fine for diagnostics.
My manometer- http://www.testo.us/online/abaxx-?$part=PORTAL.USA.SimpleContentDesk&$event=show-from-menu&categoryid=6102659
My Tachometer- http://www.testo.us/online/abaxx-?$part=PORTAL.USA.SimpleContentDesk&$event=show-from-menu&categoryid=6102657
My anemometer- http://amprobe.com/cgi-bin/pdc/viewp...id=1&type=elec
05-02-2010, 04:18 PM #13THE MORE I LEARN
THE MORE I FIND I DONT KNOW
Cancer Survivor
And Dam Well
Plan On Staying That Way
