Results 1 to 13 of 13
    Nov 2008
    DFW,TX
    cfm measurements with Digital Anemometer?
    Ok so i was looking at buying one of these and want to know some that are good some to stay away from and also do tese all have issues with needing professional expensive calibration?
    I would like one that actually has CFM on it so i didnt have to use a calc from FPM to cfm..
    Extech CFM/CMM Thermo-Anemometer looks like a decent one but may need calibration , which ones do not? these things range from $50-600 buck all being basic with just wind speed all the way up to multi function.. is this the best way to get cfm at supply's and such so i can get total cfm for the house and balance the duct cfm output?
    input on what you are using, have used and some good and bad on the ones out there?
    Nov 2008
    DFW,TX
    BTW i have a testo 510 manometer and I ordered a 18inch pitot tube that you can PUT INTO DUCT , what exactly does this measure, im not talking about the static tips but the big pitot metal tube, is this a way to measure cfm somehow?
    In the work truck
    Quote Originally Posted by acguytx View Post
    yes with a pitot tube you can do something called traversing the duct. However you need a straight run a certain distance from a 90 or transition. sometimes hard in some applications. Do you use blower fan curves?
    What type of systems are you working on?
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    NJ
    I have had good success with a Testo 416 to measure both system CFM as well as branch run (metal) volumes.
    So easy to use a kid can do it.
    Ed J
    Akron
    Being in Texas, you need a big anemometer 417.. No joking. You guys deal with a lot of flex in the attic. A large vane is used to measure airflow at the returns. The 417 will allow you to measure at the grill and calculate the CFM directly even with multiple grills. It is easy to use.
    JLB,
    In the work truck
    how do you do it? I havnt seen you around in a while and now there is a air flow question and here you are lol. Nice to see you again .
    Since were in this topic how does this tool work? Never seen it.
    How does it compare to a hot wire? I know you have to factor in for air density with the hot wire but never knew how to do it.
    to the op not to steal your post, I believe these questions related to your question..
    Nov 2008
    DFW,TX
    Quote Originally Posted by Pascone10 View Post
    just your basic run of the mill residential AND LIGHT COMMERCIAL. i just want BETTER WAY to diagnose loud ducts or systems with high static , a better way of balancing the individual duct runs in those instances.
    Jim ill call you tomorrow, thanks for the heads up.
    I have the TSI 8360 and the TIF VA500A Both will calculate CFM, I love the feature
    mesa arizona
    Frown hey
    hey fcs whats the price of that meter where u gte it at ??/
    Nov 2000
    Upstate, SC
    Depends on what you are going to do with the instrument. If you are going to get into air balancing, then you will have to send it off for that expensive calibration you mention. I've been on jobs where I had to show proof that my meter had been calibrated in the last 6 months, but most are one year. I have TSI's 8386 and their 8355 as a backup. I also have Testo's 416 mini-vane and their 410 pocket meter. All four have given me good service, although all but the 8386 were purchased off of Ebay.
    mesa arizona
    Confused hey
    nah im svc tech commericIAL... JUST WANNA GET A BASIC TOOOL TO MEASURE CFM
    Jun 2006
    New Jersey
    Quote Originally Posted by raidersfan7 View Post
    I'm a commercial tech myself. I measure airflow for diagnostics, not trying to air balance. I use a dual input manometer and tachometer to verify equipment airflow. Then if needed I'll use an anemometer at the diffuser to get a rough estimate. I'll look up a similar style diffuser in Hart and Cooley's book to get my net free area to program into my anemometer and then take about 5 quick reading to average my cfm. It works fine for diagnostics.
    My manometer- http://www.testo.us/online/abaxx-?$part=PORTAL.USA.SimpleContentDesk&$event=show-from-menu&categoryid=6102659
    My Tachometer- http://www.testo.us/online/abaxx-?$part=PORTAL.USA.SimpleContentDesk&$event=show-from-menu&categoryid=6102657
    My anemometer- http://amprobe.com/cgi-bin/pdc/viewp...id=1&type=elec
    Got the TSI off E-Bay I think I pay around $250 one heck of a deal (right plac right time.
    the TSI also has a mamometer
    got the TIF from Grainer about 5 years ago I think it was around $500,
