Results 1 to 12 of 12
Thread: Teflon Seal
    Sep 2009
    Teflon Seal
    Working on a Lennox HP with CB30M-31-1P A/H, took the R22 TXV apart to check the screen. Do I have to replace the blue Teflon washer/seal (between the TXV and LL stub, seems like a Chatleff fitting) or can re-use? Anyone knows the replacement seal p/n? TXV p/n seems to be 56J19, Lennox dealers here please confirm. THANKS!
    Massachusetts
    If you're a tech, get pro status. If you're not, we can't help you.
    Sep 2009
    SKip, appreciate your answer. However, the pro application approval is not instant, I need the help now.
    Quote Originally Posted by skippedover View Post
    burlington county n.j.
    seal should be replaced.
    Sep 2009
    I thought so, do you know the p/n for the seals? Thanks!
    Quote Originally Posted by t527ed View Post
    Quote Originally Posted by seanddd View Post
    It doesn't take 7 months either though.
    part #s might get my hand slapped.....
    local supply house will probably have them though.
    i get spares in packages all the time so i have never ordered them.
    Sep 2009
    I called JS, the counter guy hasn't got back to me.
    I ask p/n just because Lennox tends to do things in a unique way. I have several Chatleff fitting gaskets (white vs. blue Lennox ones) on hand but wanted to be sure.
    My email address is in my profile, FYI. Thanks!
    Jan 2010
    Central Florida
    Find your local lennox supplier and call them with a Model and Serial. Down here JS doesn't carry Lennox
    "Give a man a fish he eats for a day. Teach a man to fish he eats for a lifetime"
    Sep 2009
    You know what? If you are not a lennox dealer, they won't even talk to you...
    Quote Originally Posted by Mishap64 View Post
    color does not matter, its all about the size.
    In a machine room
    With 170 posts they probably have had time to review it by now, if you applied. You do know you have to send an application, right?
    Its well worth it, there is a loads of good info in the pro section.
