Results 1 to 7 of 7
    Jul 2003
    Hmm
    I am an HVAC tech I have never worked on coolers. A friend of mine got a small reach-in cooler and it seems that the compressor may be bad. There is no nameplate on the cooler anywhere. All I could find was a plate on the compressor and it reads as follows:
    AJ311 BJ-424
    G B22 82C 95300 AJ6435A
    V115 Hz 60 LRA 38.2
    v110 Hz 50 PH1
    It is a small unit I don't think the LRA is 38.2 but that is what it looked like. Anyway what brand, Hp, refrigerant type would this be most likely R-12 I figure but what about the rest?
    Take those #'s to a supply house that sells Techumseh Compressors. They will help. And yes the LRA is 38 amps if you wrote the #'s down right.
    Apr 2002
    most of the time in the Philippines
    It's medium temp, normal starting torque, 3500 btu's at a +20º evaporator, R-12. At http://www.tecumseh.com you can look up this stuff for yourself. You can also download/print a Tecumseh Compressor Service Manual or, alternatively, call them and they'll send you one for free.
    Dec 2003
    AJ311 BJ-424
    V115 Hz 60 LRA 38.2
    v110 Hz 50 PH1
    The replacement compressor is Mod# AKA9434AXA B/M# AK159AT-038-J7. Your local wholesaler should have them in stock.
    puerto rico
    LRA (38.2)7=5.4amp
    You say the unit may be bad.
    What has been done thus far to determine what condition the unit is really in?
    Do you have an "Annie" Hermetic anyliser? Are you familiar with the clip cord jump start method?
    Has anyone ohmed out the compressor?
    If ya got ohms, you got one of two things.... either bad starting components; relay, capacitor. Or you got a mechanically locked up compressor.
    Cause if you got ohms, you have already ruled out open windings and ground shorted windings.
    Also make real sure your voltage at the unit is high enough to start the compressor. Extension cords are NOT good for itty bitty units.
    Jul 2003
    Thanks for help
    Thanks for all of the help guys. I've looked it up also and will also check it out. Comp. has hard-start kit on it. I'll check it then the windings.
