    Dec 2009
    Import graphics to an enterprize server
    I am using work place pro and I can't figure out how to import a jpeg or a gif file into the local library on the server.
    Jul 2002
    If you're using WPP on the same machine as the server I believe you can just use Windows explorer to copy it into your images folder under Naigara\Stations\stationname\images and it will show up. You may have to stop the station or close & reopen the llibrary. What have you tried? If WPP is on another machine just open your local library and copy/paste into the remote library.
    Dec 2009
    Wpp is on my laptop, the server is in the data center and the graphics I want to import are on a network drive. I have tried copy and paste but that didnt work.
    Feb 2007
    Helena, Montana
    try copy and paste in Windows, not in WPP. That should allow you to get it to the local library and it can be moved after that.
