Results 1 to 7 of 7
    is there a proper time to put in r410
    ive got a new system in the winter,he told me he would be back in the spring to put in r410 properly. i live in phila pa,how warm should it be outside to finish the job,thank you
    Apr 2010
    Montgomery, Texas
    Heat Pump or Splilt A/C system?
    What kind of system was installed? Was it a heat pump or a split A/C system?
    burlington county n.j.
    i like to see 65-70 and dry outside to double check the charge on installs we did over the winter.
    Massachusetts
    Quote Originally Posted by t527ed View Post
    I don't care how dry it is but I need to see some load on the system.
    it was a split ac system,no heat pump
    Apr 2010
    Montgomery, Texas
    Charging
    Yes, 66-70F would be ideal to get closer to design conditions. Anything under may be inaccurate.
    Quote Originally Posted by skippedover View Post
    you want to do it in the rain?????
