Results 1 to 8 of 8
Thread: Dead thermostat
    Apr 2010
    Dead thermostat
    Have a Bryant HP system. My Honeywell T8611M tstat went blank some time last nite. No extreme weather. Circuit breakers were not tripped, but recycled them anyway including air handler. Have 24v across terminals R & C, so power should be ok. No battery in this unit. Any thoughts ???
    Myrtle Beach, SC
    You need a new thermostat.
    Remember, Air Conditioning begins with AIR.
    Nov 2007
    Ottawa
    Stat is finished!
    Apr 2010
    Frown
    It's hard to believe they crap out with no moving parts, only 8 yrs old. Thanks for the quick replies.
    The 8611M was a piece of.
    You actually got a long life out of it.
    Apr 2010
    Any suggestions as to its' replacement?? And does that mean I have to replace the backplate?
    Get a good contractor to set you up with an IAQ thermostat. Much better control of the aux heat.
    And yes, the back plate is a part of that thermostat. And can't be used with another one.
    Apr 2010
    Thanks again for the info.
