Results 1 to 13 of 13
06-04-2004, 09:15 PM #1
- Jan 2004
- Mt. Washington, KY
- 28
have a copeland scroll on a walk in freezer, that utilizes liquid injection. Compressor failed and I had to replace. The old model compressor had a liquid injection line solinoid valve with a capillary canister. The new compressor utilizes a DTC liquid injection valve. Question is this: Should the liquid injection line solinoid valve been removed or should it have stayed in place? Does the DTC regulate refrigerant and prevent refrigerant migration?
06-04-2004, 10:57 PM #2
That injection system is controled thermostatically, kind of like a TXV. I believe if the compressor is not hot, it does not feed. Solenoid is not necesary.
06-05-2004, 07:40 PM #3
I would leave it in place, i think they are still needed
06-06-2004, 01:06 AM #4
- Feb 2004
- Medford Oregon
- 807
the new style compressor has fitting for the DTC valve,
this fitting is 1/4"od. just put your cap tube into it, leave the old solenoid on. the 1/4"od designed to allow replacing old comp as is.
06-06-2004, 11:01 AM #5
- Mar 2004
- South
- 51
It should stay. The solenoid will prevent migration into the compressor during off-cycle.
06-06-2004, 12:31 PM #6
ooops, I did it wrong.
06-06-2004, 01:00 PM #7
Copeland Scroll - Cap tube to DTC valve....
Here's the Copeland AE Bulletin that discusses this issue:
http://www.customer-copeland-corp.co...EB/tae1299.pdf
The LLS isn't required, but it won't hurt to leave it in the circuit.
06-06-2004, 02:33 PM #8
Thanks Ice, I thought I read the instructions correctly.
06-07-2004, 09:19 AM #9
- Mar 2004
- South
- 51
Sorry frozen- I was probably a little strong stating a personal opinion on the use of a solenoid with the DTC. I think the DTC is a great improvment over the cap tube for liquid injection, but I'm not sure I trust it to stop all flow after compressor shut-down.
Sidney has the official word and you should certainly feel comfortable following the recommendations in the AE bulletin.
06-07-2004, 06:31 PM #10
I don't sweat the small stuff emerson. I don't even mind making mistakes, as long as I do it only once. To error is human, to keep repeating that error is dumb.
06-12-2004, 07:58 PM #11
- Jan 2004
- 28
Hey guys thanks for your responses. I followed the instructions from copeland and removed the solenoid valve. If I find any problems with this set up I'll let you know.
10-06-2011, 09:33 PM #12
Just the thread I needed had the same exact question on a job today!
10-08-2011, 12:10 AM #13"The problem is the average person isn’t tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and it’s not in the movies they watch, and it’s not in the few books that they buy, they don’t get it" - Jack Canfield
