Results 1 to 13 of 17
    Apr 2004
    Is there a way to try and reverse rotation of a mechanically locked single phase compressor.
    I ran into a situation where I made sure all starting componets were good along with triangulating compressor windings on a small semi-hermetic reach-in freezer compressor. I sure would of liked to be able to try and free up the thing temporarily to see if anything else had gone south or caused compressor problem in first place.
    Thank you for any replies!
    Nov 2003
    Use an Annie.
    Jul 2001
    Gold Coast of Connecticut
    I try to switch the start and run to see if you can free it up. I would just condemm it since it will most likely happen again.
    Orange County CA
    I'd do that plus I would pull the head (carefully not tearing gasket ) and push down the pistons.
    If that won't move it you're done .
    I have been known to kick the hell out em.
    Hey cockroach, don't bug me! ©
    (in truth, Dicee gives the job to Jack, and he kicks them)
    reverse
    I didn't notice if this unit is hermetic or semi-hermetic,
    the sealed tin can, alittle hard to open up and take head off, I have had one recently lock up when trying to start by the oil pump end, are you sure the start parts are good,
    usually if new start parts won't work, unit is bad...
    or if you know how to wire in a test lead, if pressures are equalized, compressor should run..
    hem
    Jul 2001
    Dice you have some merrit in kicking the hell out of it. I have seen guys hit them with a hammer to free up tin cans before.
    Sep 2001
    East Stroudsburg, PA
    I've got a three pounder that has been known to put a nasty divot into an AE4440.
    A true "Annie" can reverse it, but like previously stated, it'll only get you out of the woods, after that, at the end of that long dark tunnel, there will appear a light. It is the approaching train. get yourself a new compressor.
    Jul 2000
    Guayaquil, EC
    If I determine that the compressor is stuck I usually just condemn it and replace it. In the old days you could try the Annie deal and reverse the rotation to get it going and the customer would be truly grateful. Today if you do something "heroic" like that you will be married to it because the customer believes you actually fixed it the first time.
    Sure there are instances where you can free one up and it runs fine for years, but that's the exception not the rule. I'm in this business to make a profit and I don't like to have to go back and "re-fix" something for free.
    I've got a K-Body Copeland on a C-Store ice cream freezer unit that I whacked with my 3 lb hammer on a Sunday morning a few years ago, it started and I haven't had a problem since..............go figure.
    South
    Please!
    An HVAC/R professional does not whack a compressor...
    He performs an "impact adjustment."
    Orange County CA
    I had a Meat prep room go down on a Sunday about 2 years ago .
    A Copeland 5 or 7 hp (I forget)was locked . The setup was all singles and had been remodeled and retrofitted so many times , it would have been a real deal change it. Anyhoo, I was desperate. It had a 1965 serial# so I had nothing to lose.
    I reversed and reversed and reversed and reversed and reversed and it finally broke free. When it did I cried like a little girl (tears of joy). It ran for about a year and a half until the store got new Hussmann racks.
    I swear I used to salute that compresser everytime I passed it after that day.
    Jul 2000
    Guayaquil, EC
    Originally posted by emerson climate tech
    Please!
    I like that. I usually describe it as "fine tuning" the system.
    Again, since we're in this for profit, how much should I charge for using the "Impact Adjuster"?
