Thread: 30gtn 130
04-22-2010, 09:51 AM #1
30gtn 130
hey guyzzz., i am working on a carrier 130 ton air cooled liquid chiller., is there anyone out there that may have a pdf fiile that i may be able to get from you great people., hopefully the pdf is an IOM MANUAL., i do have a few questions., the machine is up and running but what i want to di is a dry run to check all the sensors., do i need the machine offline to perform this action., im sure that i do., allso i found a small leak on one of the compressors., can i isolate this circuit ., and if so ., is the gas stored in the condenser like a regular pump down? because if so., there will also be gas in the compressor as well., anyways , any help would be nice., ., also any service tips would be greatful
04-22-2010, 02:02 PM #2
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,511
You have a scrolling marque . The only sensor in actual fluid is the EWT sensor. The rest are in wells and the condenser sensors are strap on type. So all can be exposed to air temp or your clamp on thermometer.
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
04-22-2010, 10:19 PM #3
04-22-2010, 11:04 PM #4
- Jul 2000
- Dallas,Texas
- 4,806
04-29-2010, 07:14 AM #5
thanks man., got it
