Results 14 to 26 of 35
Thread: silver solder
    Apr 2003
    Somewhere in the Caribbean
    I work mostly in commercial refrigeration, I generally don't use anything except 15% silver. soft solder and hot gas defrost are not a good combination.
    Sep 2001
    East Stroudsburg, PA
    Good practice, but I'm here to tell you, if your HG defrosts are anywhere near 450 degrees F, you've got bigger problems than what solder to use.
    Apr 2003
    True, but expansion / contraction due to defrost temperature swings in piping, along with the pressure surges at defrost are reason enough for me to be wiser than I am frugal.
    Earth
    For some reason hot gas does not like 45s either.
    Jul 2000
    Guayaquil, EC
    Piping for HG defrost is very susceptible to thermal expansion/contraction forces that result from the thermal changes going on.
    Just imagine a two-pipe HG system (like all market HG systems) where a 200 ft suction line at minus something degrees suddenly gets hit with one hundred and something degree hot gas. The pipes have to move and the stress is greatest at the joints. 45 Deg ells are inherently weak and any good supermarket specification will prohibit them. Stab-ins and reducing bushings are no-nos too. A&P back in the old days required the proper reducing fitting at every reduction and branch. When's the last time you saw a 1 5/8 x 1 3/8 x 7/8 tee used on a job?
    It's not uncommon to have a long run want to move 4-5 inches due to the thermal change. This is where I think the soft-solders like 95-5 and Sta-Brite lose it big time.......with the stress over time. Been there.....
    Earth
    I don't think I can ever remember seeing, or piping the required expansion loop.
    Jul 2000
    Guayaquil, EC
    Do you mean the loop in the Hussmann install books? No, I never saw or did one like that either. Usually you have a 90 in the line and you have to allow that joint to move by moving the clamps way back.
    Earth
    I think it is in the Kysor/Warren book too.
    We never clamped anything but our main suction risers, and liquid lines coming in to the house.
    Our saddles were PVC gutter, cut in one foot pieces. We would drill two holes in the saddles to accept push pins. The kind in door car panels. The pins would straddle the unistrut so the saddle would not dislodge during expansion.
    You don't know how many times, I have seen a plumber get busted, for having a PVC vent in the return air. The Inspectors never said a word about our saddles. Go figure.
    Sep 2001
    I've got a box of them, and a box of 1-3/8 x 1-1/8 x 5/8 in the shop. Covered in dust. Need any???
    Sep 2001
    When I first started, we installed the expansion loops in a few stores. A few years later, I recall going on a call where one of them broke. That was the last I heard of them.
    45's and street 45's are banned by every single chain that I've ever worked for. They are not just banned in refrigeration, but in the plumbing, and even the drains. (Including the walkins...)
    Why?
    Jul 2005
    Tulsa
    bump for a good thread .. at least the first part
    Aug 2011
    San Jose California
    icalled haris and englehard.... staybrite 8 is a stronger joint because it doesnt weaken the joint due to heat.. flame on 15% silpos etc... it is what it is
