    Jul 2009
    TAR weight of 410A cylinder
    Can someone tell me what is the TARE weight (empty weight) of a 25 lb tank of 410a? That is an empty tank of 410a with no freon in it?
    thanks in advance.
    No.
    You can, however.
    The Tare Weight (TW) is stamped into the cylinder somewhere.
    Each cylinder is slightly different.
    Virginia
    New virgin refrigerant cylinders (25/30lbs) only have a net weight labeled on them - in the case of your 410a cylinder, it's 25lbs.
    A full 410a (25lb cylinder) weighs about - 34lbs 2 oz (gross weight)
    subtracting the weight of the refrigerent - 25 lbs 0 oz (net weight)
    so the approx. empty container weight - 9 lbs 2 oz (tare weight)
  4. Likes nathankerr, Disabledsparky liked this post
  5. #4
    Jan 2010
    No.
    Cylinders with the bail style handle weigh different than the stamped type handles. Recovery cylinders have tare weight stamped. And if your cylinder has (tar) on it say from some roofer who knows. Just joking Too Tall
  6. #5
    Breslau, Ontario
    each cylinder is slightly different, the tare weight will be stamped on the handle
  7. #6
    Jul 2009
    Thanks to all for your help. I'm an apprentice tech learning the trade. Your help and advise is greatly appreciated. I looked all over the darn cylinder but didn't look on the handle. ha. thanks.
