Results 1 to 13 of 22
    Nov 2000
    Coastal Georgia
    Confused
    How do you get to the start up folder or registry?
    Re-install 98 or 2000 and get rid of that POS operating system!!
    Hell Hole Swamp
    To access the start up list... start...run... type msconfig, then select the startup tab.
    access the registry the same way by typing regedit.
    Nov 2000
    Coastal Georgia
    Thanks. Where is the start up list?
    [Edited by James 3528 on 06-02-2004 at 07:20 AM]
    Jul 2000
    Ottawa, Ont. Canada
    What happens when you "right-click" on the Start button, and then select "Explore"? On Win2000 that starts up Explorer right on the Start Menu.
    don
    don sleeth - HVAC-Talk Founder
    HVAC Computer Systems
    Heat Load Calculation Software
    Nov 2000
    Coastal Georgia
    don
    Bingo. Your're good for some thing!
    Nov 2000
    Coastal Georgia
    Got a home page hijacker. Will have to work on it later. Thanks
    Nov 2003
    Use system restore.
    Nov 2000
    Coastal Georgia
    Did that did not work. This bug is planted deeper.
    SW Florida
    Nov 2000
    Coastal Georgia
    Got all that stuff. Still does not work
    Sep 2001
    prov.r.i.
    windows xp start up
    try spygate personal firewall run your anti virus,that should find the little bastard.
    if at first you dont succeed,then skydiving is not for you
    Hell Hole Swamp
    Update your programs before scanning... (ad aware or spybot)
    If that doesnt work try Hijack this
    http://download.com.com/3000-8022-10...ml?tag=lst-0-5
