    Sep 2003
    In a previous post,cobitech suggested a method for charging units.This seems to be a great tip. I appreciate reading and learning things like that very much,as I am sure a lot of people are that use this forum. What I want to make sure of is by low temp does that refer to a freezer,medium temp a fridge or reach-in cooler or the like,and high temp maybe a flower case or similar?My thanks to whoever would like to clarify this for me.I want to be sure of what I pick up in this forum.Thanks again.
    Apr 2001
    Camel City, NC
    low temp.
    I was hired by an HVAC Co. that referred to everything with evap. colder than AC as low temp. I was hired for my low temp. exp. refrigeration and icemakers. PS The more I read the less I know I know.
    Be safe not fast. body parts don't grow back
    Orange County CA
    I think you're asking
    low temp = 0* or lower
    Orange County CA
    med temp is meat cases , dairy cases...(above freezing)
    Talking This may help
    mark7,
    I hope this may help a little, I'm saying it like
    selfemployed The more I read the less I know I know.
    wicewater
    (Low-Pressure Applications)?
    The application in which the suction pressure is in the range of 0-10 PSIG with an equivalent evapouration of -30 to -14 C .
    Generally used for low-pressure applications like Deep freezer.
    (Medium-Pressure Applications)?
    The application in which the suction pressure is in the range of 17 - 40 PSIG with an equivalent evapouration of -15 to +15 C .
    Generally used for low-pressure applications like bottle coolers.
    (High-Pressure Applications)?
    The application in which the suction pressure is in the range of 25 - 55 PSIG in R-12 / R- 134a and +25 to 95 in R-22 with an equivalent evapouration of - 6.7 to -+12.8 C.
