Results 1 to 8 of 8
Thread: purging hoses
    Apr 2010
    Hmm purging hoses
    Guys
    I was wondering if and how you guys purge your guages when you put them on equipment just to take pressure readings. Thankyou Randy
    Apr 2010
    Inwood, WV
    Me too.
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by Randykissling View Post
    Guys
    FWIW, If I am just taking some readings, I do not use a manifold set, I have gauges with a 1/4" flare adapter on them...Never a loss in refrigerant charge and don't have to worry about contamination....
    I use different gauges for different oils also..
    I have three sets for different refrigerants....
    Cheap investment compared to the wear and tear on the manifold...
    GT
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
    tx
    There really is no need to purge a hose to take a pressure reading. The only time you need to purge is if you are going to add refrigerant in which case you don't want the refrigerant from your bottle pushing that air in the hoses into the system. I am sure some of these guys who work on systems that may or always run in a vaccuum have some other sets of rules they have to follow as even hooking up could add non condensables.
    Bad information is worse than no information at all.
    There are three kinds of people in this world. Those who can count and those who can't!
    Apr 2010
    Inwood, WV
    Good info. Thanks.
    Apr 2010
    purging hose
    great thank you
    Jun 2010
    Quote Originally Posted by GT Jets View Post
    GT
    Same here. I won't get the gauges unless I'm sure there's a problem. We do a lot of maintenance and if you put gauges on every time, your just looking for trouble.
    Quote Originally Posted by surenuff View Post
    I'm kinda new to low pressure, but most of the time, there are gauges or a nifty touchscreen control panel already on the machine used for day to day operational checks. The other times, if you have hoses connected, you're either adding or removing refrigerant, or you have the machine slightly pressurized to service something.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
