Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 49
  1. #27
    Nov 2009
    This upload interface is a little clunky. Hopefully the troubleshooting guide uploaded. Hope this helps.
  2. #28
    Nov 2009
    And another one. Is this panel the older one with the numeric codes? Or the clear L display?
  3. #29
    chiller plant
    Is this job Mds Pharma ?
  4. #30
    ottawa canada
    The 80ton RTAA was never manufactured with a numeric code display .
    Is posting confidential service bulletins a good idea Scott ???
  5. #31
    Nov 2009
    They are "GENERAL" Service not confidential. The RTAA is out of production and I'm sure Trane would like to help wherever possible.
    I usually jump in one time, and post with as good information as possible, and then leave the thread. I don't have much time to visit here. I want all Trane equipment to work properly, so just providing what I can. I did not download those TSB off the Trane Tech side of the site. He could have downloaded them himself.
  6. #32
    Quote Originally Posted by scott_RWS48 View Post
    looks like a confidential service bulletin to me. trane wants all of their equipment running well. but they will not release any confidential bulletins...most confidential bulletins anymore do not contain a lot of "special-super-secret" info...
    Last edited by jayguy; 04-26-2010 at 07:36 AM. Reason: for the word 'not'...makes a lot of difference!
  7. #33
    Nov 2009
    LOL...way to go guys, been at Trane a very long time, no need to stick my neck out to help. Don't worry about getting information from this Trane guy anmore. Good job
    I remember trying this forum years ago and ended up in all these side battles. I realized I didn't need to be in the middle of it. After all I don't need to be. Guess what I did the 1st time is what I'll do again. Say good bye
  8. #34
    if you want your panties in a wad then fine...the questioning of the confidential service bulletin posting was for your benefit. if you really are a trane technician (still anyway) then you are probably violating the 'never tell any of the super secret info' clauses that you signed.
    i do not care if any service bulletin gets out...i really don't. but i don't post them because i want to keep my job. if you don't or you are not worried then fine...post away.
  9. #35
    Sep 2006
    ok my advice check your
    check suction and saturated sensor
    check your connectors on the module
    circuit unit charge
    compressor starts unloaded at around 40 percent should jump up to 60 percent when female is energized
    check expansion valve control response
  10. #36
    Not in Iran
    Quote Originally Posted by jayguy View Post
    im not a trane employee, however i am always studying trane ioms and i have been to many traing classes as well a teardown schools., i like sb and i wish i could get some more so when i do go out and work on a machine i am prepared., ,. any input
  11. #37
    Not in Iran
    Quote Originally Posted by graham View Post
    There aren't vfds on the condenser fans, just fan cycle controls based on head pressure
    Bingo !!!!!!! Houston we have a problem .
    hey graham, can u explain this, if temp is cold outside and there is a call for cooling, i know cond fan will come on for cooling the cond, which would drive head and suction down , i know what a vfd does , and i know what fan cycle does., and if oat sensor set correctly,.
    idk ., what really is goning on, also the fans are already cycling i think.,
  12. #38
    what part dont you understand???
    Quote Originally Posted by mlkwal1 View Post
    true knowledge exists in knowing that you know nothing.
  13. #39
    ottawa canada
    No head pressure = no suction pressure = no oil movement = no chiller ..Done
