Results 1 to 13 of 49
04-16-2010, 10:41 PM #1
- Nov 2005
- 1,311
RTAA low evap ref. temp. hair falling out!
MN: RTAA0804YN01A3D0BD
SN: U02M07829
This thing is driving my nuts. Tied into Summit. Continual low evap ref. temp faults, mostly in the winter months. I have done everything I can think of, from checking the charge to replacing the EEV. Has anyone had this problem?
I get about one fault a month.I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
04-16-2010, 10:51 PM #2
Do you know when it trips? Start up, unloading, loading...etc...
There are several causes....The EEV is rarely the issue...
A contaminated refrigerant charge can do this...Has anything been replaced before you R&Red the EEV?
How certain are you that the slide valve is not sticking?
Put up some more stats...I love these!!!!
GTIf a day goes by and you have learned nothing, I hope you got a lot of sleep.
04-17-2010, 12:38 AM #3
How is your flow thats where I would start. Sensors and connections next. Does your flow vary possibly under light loads when the air handlers are bypassing. Out there but is your flow switch stuck in the made position allowing the chiller to run with no pump. Only reason I say this is I just found this exact scenario last week. Are you running glycol and have your settings been changed accordingly.
04-17-2010, 08:06 AM #4
I'd concentrate on the slide valve piston. Even if it isn't sticking, it could be loading too fast. Start it up and watch the RLA% in menu 2. If it makes big jumps with each pulse of the load solenoid instead of small incremental increases, then the rings are worn. It would on;y take an hour or so to pull the plate and check. Unthread the nut a little way and screw one of the plate bolts into it. If you're able to easily slide the piston in and out, then the rings are too worn and you need to replace the piston.
Low Pressure Forever!
If you know heavy metal, you can work anywhere-Dave Andreson
Anchors Aweigh my boys, Anchors Aweigh!
Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
04-17-2010, 09:08 AM #5
How cold do you get in the winter? If it happens mainly in this season, it sounds to me like you may be cooling the loop only w/ no load. I agree with Mustardman, what kind of valves do have at the air handlers? You got an 80 ton chiller, does the trip follow one particular circuit? Or does it affect both? I think there was a bulletin out on this, I'll check my books. Hope this can help.
Sic Semper Tyrannis.
04-17-2010, 12:37 PM #6
Water or glycol ??? Is the ucm set up properly ??? Flow,flow ,flow is it primary secondary ,variable etc etc. Dont blame the chiller look at the whole system and as far as the slide valve , yes its a possibility but just check the amps at start up to see if its starting loaded . Maybe the flow drops off too quickly under low load and the UCM doesnt back the chiller off fast enough and bingo she trips .
Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
04-17-2010, 08:28 PM #7
- Nov 2005
- 1,311
I think you may be onto something. There is not a lot of load and there are no valves at the air handlers. The flow stays constant I assume on pressure, 2 chillers in series and vfds on a lead lag pump skid. If there is a bulletin that would be great! Both chillers have had this fault numerous times.
This is a new contract for our company and the only history I have on it is from the B.E. and the fault logs in Summit.I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
04-17-2010, 08:34 PM #8
- Nov 2005
- 1,311
04-18-2010, 11:30 AM #9
Also if it starts when OAT is below 50 and it doesn't have VFD on condensor fan it will suck evap down to trip point because of low head pressure.
04-18-2010, 01:39 PM #10
Ok you're regulating flow w/ the pump vfds, you'll need to determine how the vfd's are throttled. I am assuming they're based on temp rather than pressure, because coils are running wild. Check your minimum speed setting on your vfd's & start there. The Bulletin relating to low evap trips is RTAA-SVB07A-EN, it shouldn't pretain to your chillers since yours are 2002 machines(bulletin for 2001). I don't have it on pdf or I'd post it. My opinion is you've got loop issues too cold temps causing your fault, get some more info on the building, check & make sure your chiller is set-up right. You can set the chillers up on chilled water reset, that way you're not allowing your loop temp to drop too low and fine tune it from there. Hope this can help.
04-18-2010, 02:00 PM #11
Member
- Aug 2004
- DFW
- 147
RTAA
Check ucm settings. What is the setpoint? What is the start/stop temperatures. Is it process or comfort cooling? If comfort and below 42 degrees you will see nuisance trips. Fan inverters? Whats the outdoor air temp? Does the chiller have a outside air sensor? Does it have upgraded eproms to control condensor fans better than the previous algorithm? Are the water temp sensors accurate? Water flow ok? Check the IOM for water pressure drop charts. Lots to look at but these are tough machines.
04-18-2010, 03:36 PM #12The weak aren't destroyed by the strong.
The weak are destroyed by the under-estimated.
I know a famous song that ends in 'my nose'. The artist is dead. Know who?
04-18-2010, 06:21 PM #13
- Nov 2005
- 1,311
