Results 14 to 26 of 29
Thread: GE 10 ton
07-25-2004, 01:37 PM #14
- Jul 2004
- 4
coil crud
Could also install a UV light near the coils. The light will clean the crud off quickly and prevent it ever coming back. Just leave the light on.
07-25-2004, 05:06 PM #15
- Apr 2001
- Camel City, NC
- 6,225
LOL
Be safe not fast. body parts don't grow back
07-26-2004, 10:23 AM #16
The unit in the picture probably has a SEER of about 4
07-26-2004, 05:55 PM #17
- Apr 2001
- Camel City, NC
- 6,225
Yea but lower seer units last longer and don't have many gadgets to replace so they cost less in the long run.Originally posted by benncool
08-01-2004, 01:10 AM #18
Water Tube Condenser
Shared this before , this old Carrier R12 was running when we changed it out...
They don't make quaility coils like this any more.
This coil installed flat and the louvered condensate pan caught dripping condenstae. 40+ years old and no leaks :-)
[Edited by AllTemp on 08-01-2004 at 01:16 AM]AllTemp Heating & Cooling
08-01-2004, 01:52 AM #19
Professional Member*
- Jun 2003
- Lenexa, KS
- 432
Not true... if you compare a heat pump made today to one made even 20 years ago, you'll find there are no mechanical timers, coils, relays, etc. Many of these components have been replaced by simple solid-state controls, and have thus eliminated potential component failures. Air Conditioners made today are made pretty much the same as 20 years ago... motor, compressor, contactor, capacitor.Originally posted by selfemployed
I give you that the quality of the components themselves may have changed. That compressor is a tank, and nobody makes them like that anymore."We are what we repeatedly do.
Excellence, then, is not an act, but a habit." -Aristotle
08-01-2004, 06:49 AM #20
- Apr 2001
- Camel City, NC
- 6,225
Old equip.
Nice pics alltemp they do last beyond their time. Had to clean and replace gaskets on a few condensers like those. gschra11- that was a joke inpart
The old stuff just wouldn't quit and were built to last. Cost of repairs causes most equip. to be replaced today, even when its less than 10 yrs. old. Thats not all bad.
08-07-2004, 04:50 PM #21
- May 2003
- Dallas/Ft Worth, TX
- 439
Those old GEs just keep on going. I worked at an apartment complex and the majority of their units were old GEs from 1972-73. and a lot of them are still going today. I didn't like the trickle circuits tho when I was just starting out in HVAC I would get the crap shocked out of me all the time.
08-12-2004, 01:26 PM #22
- Aug 2004
- 37
INFORMATION YOU NEED IS IN YOUR NECK OF THE WOODS.
That compressor looks like a 7 tonner.You'd be suprise to see that baby run as its name implies- for many years to come
08-01-2005, 12:18 PM #23
- Aug 2005
- 1
I got one too
Hi i am currentlya business owner and i have one of this unit and the compressor just went bad and i cant find one, im going to upgrade and i see there quite a few fans of this old GE's, anyone interested in buying this dinassour?
10-18-2005, 09:46 PM #24
Member
- Oct 2005
- 91
what does the air handler look like?
10-19-2005, 07:18 AM #25
Re: The propane torch trick
Very good post. The first time I used this method was in 1969. I was a GE dealer. Used to use the torch with what GE called "A Lazy Flame". Great to use on dog hair. That serial # is Feb. 1972. I have a lot of old res. units stll kicking with the dome top. Installed thousands of them. Love that roto-com and the 3 legged mount. Some even had a fuse on the run wire.Originally posted by gschra11
Spine-fin is all-aluminum, and since the way they make it involves aluminum spines sticking out instead of aluminum plates, the spines can bend very easily. For this reason, you can't hit it with a jet of water because:
No, this isn't some crazy thing I dreamed up. This is what Trane said to do at one of their training sessions. It actually works very good.
Hope this helped.If you really know how it works, you have an execellent chance of fixin' er up!
Tomorrow is promised to no one...
03-24-2006, 07:39 PM #26
Member
- Oct 2005
- 91
Update picture please,
Hey selfemployed, Can you please repost or update this thread call "Ge 10 ton"? Thank-you
