Results 1 to 7 of 7
    Jul 2005
    Milk cooler temp dial, 1 thur 8.
    Temperature thermostats on small milk coolers, that store 8 oz cartons of milk, are always marked ' 1 2 3 4 5 6 7 8 '. Which is the coldest setting?
    Usually theres an arrow that tells you which way is colder. If not, the direction that turns on the compressor is colder.
    Queens,NY
    What brand and model milk chest?....I know with "True" and "Beverage Air" milk chest's turning the thermostat clockwise will give you a colder setting.
    Southold.calm
    Clockwise is colder. The #’s are just a guide start at mid range and let it run. Check it after several hours and adjust accordingly.
    Apr 2005
    AZ
    as above clockwise colder which will b a higher number
    Apr 2010
    madison wi
    yup, typically the higher the # the colder it gets just like the fan speed in youre car
    Jul 2005
    Thank you all for your replys!
