Thread: TRANEN ECGAD
    Apr 2010
    TRANEN ECGAD
    Does anyone have the technical data of the TRANE ECGAD207 screw chiller?
    Unfortenly the Trane does't give such a "value" information!!
    Best regards
    Metro ATL
    Do you have a serial #? Never seen an ECGAD. I have seen a CGAD but it isn't a screw machine. Where are you located? In the States or abroad?
    Apr 2010
    Quote Originally Posted by jemawalton View Post
    No it isn't at USA. It is at Europe, and it has 2 screw compressors
    A land down under
    Vzacharis, check your model # again, this might be the reason Trane can't help you..
    Model ECGAD is a European manufactured cold genorator air cooled D design sequence which had reciproicating compressors.
    If your chiller has screw compressors suspect you are after ERTAA 207 or ERTAB 207.
    For the European market these chillers could have R134a, R22 or R404a refrigerant, be 50/60 hz and standard/ high ambient so you would need to be specific and supply the full model # and serial # to obtain the correct tech data
    Apr 2010
    Quote Originally Posted by Screwit View Post
    Screwit, thank you very much for your reply and you were right! The two compressors are reciprocating,R-22,compressor type:CRHZ-300, at 1450rpm,50Hz!
    Does anyone has the technical data of this units?
    A land down under
    Vzacharis, can you add your email to your profile
