    In my Whirlpool Side-by-Side Refrigerator, I am getting a significant build-up of frost; particularly around the ice-maker and the immediate surrounding areas. What is causing this, and how can I fix it?
    do the gaskets make a good seal all the way around you doors??
    I'm guessing they don't but wouldn't know what for sure to look for. I know when I pull it open, it doesn't have as tight a seal as the refrigerator door does. Is this something I can fix on my own?
    Earth
    This may sound silly. But make sure you water line, is tapped into the cold not hot water suppy.
    puerto rico
    hello friend;check back the refrigerator,in the a/maker water in) And seal the area. REMENBER THA ICE IS HOT AIR CONSTANT IN TO THE REF.
