Results 1 to 7 of 7
    I am looking for something to make coil repairs with. Non brasing, non soldering.
    I dont have a problem with making coil repairs. I have been sucessful using the low temp solder kit on ALUMINUM. But my skill is best in epoxy repairs.
    I have a tremendous sucess rate. But my holes to patch have usually been small ones.
    I would imagine that with all the breakthroughs in chemistry today, we would have something we could simply clean the pipe, paint this stuff on, apply either some heat or a second chemical to for a reaction like a catalyst ...then it's ready to return to service.
    Has anyone found something simple and sucessful?
    Jun 2001
    There's some stuff you may find at your supply house (I can't remember the name of it). Anyway, it comes in a green stick form and you lightly heat the aluminum and then rub the stick over hole and build it up. It is some form of epoxy. I've had success with this stuff on refrigerator coils. Also have run across aluminum rods that work pretty good.
    This isn't what I have used but it may work
    http://www.devcon.com/devconfamilypr...116.0&catid=23
    Another
    http://www.devcon.com/devconfamilypr...110.0&catid=15
    [Edited by bb on 05-23-2004 at 05:17 PM]
    Dec 2001
    Chicago, N/W burbs
    a new coil works quite well, or so I've heard....
    R2B4BTU
    less call backs too.
    Jul 2001
    Gold Coast of Connecticut
    I have used those sticks till the new coil comes in, but never forever.
    Oct 2001
    Waterford Michigan
    Originally posted by appltech1
    http://www.laco.com/cat/index.html
    I've use Laco Heat Sticks for years with great success.
