    Oct 2009
    Confused Lenox Torch Tip Size ???
    I can't seem to figure out what tip size to buy for my Lenox "B" air acetylene torch. I do mainly residential and light commercial. So I'm looking for 3/8 through 1".
    Help?
    Fuquay Varina, N.C.
    If you go on the Lenox site, they have a chart there that tells you which tips you should use on which size pipe. Here is the link if it post right. http://www.lenoxsaw.com/enUS/Product...ORCH_TIPS.html
    they have different types so choose which style you want and pick from there.
    RSES Member.
    Mainstream Engineering Certified.
    HVAC/R PM Technician.
    410A, & GREEN HVAC/R Technician.
    Indoor Air Quality Master Technician.
    NATE Core.
    Working not as to please men but to the Glory of Christ my KING.
    I'm on the road to Shambala
    A # 14 tip will braze or soft solder those sizes fine. A #32 tp will do up to 4 inch if you have a big enough tank.
    Scooter
    UA Local 630
    West Palm Beach, Florida
    RSES
    FL. Class A License
    www.enterpriseaire.com
    Oct 2009
    Yep. That's what I'd been looking for... knew it was on there somewhere.
    Oct 2009
    Thanks. That's what I was looking for. Knew it was on there somewhere.
    Sep 2009
    Stumptown,USA
    If Turbo torch tips will fit that lennox check out the MSA-8 tip from turbo torch. It will Braze up to 3/4" copper and it is like 4 #A2 tips together in a brass heat sink. It doesn't whistle like the other tips and it looks like a mini-rosebud. You can also adjust the flame on this one(you can't on the others). It is my favorite tip.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
Tags for this Thread
