Thread: Residential refrigerator
04-05-2010, 07:48 PM #1
- Nov 2004
- 10
I have an Amana side by side with a solid state defrost control. Where can I get trouble shooting information? Last domestic refrigerator I worked on had an electromechanical defrost timer which you could turn to advance though time sequence.
04-05-2010, 09:26 PM #2
Try this...
04-06-2010, 04:51 PM #3
- Sep 2006
- 49
Hi
If I remember correctly you can diddle the door switch 4 or 5 times in 8 seconds, and it should start a defrost sequence. Note the compressor must be running when trying to force in a defrost. To terminate the defrost unplug unit for 30 seconds. Defrost time will vary according to model and time unit has cycled on.
T to L2 should go to heating element. I have more info if you need it.
Max
04-07-2010, 03:22 AM #4
- Jan 2010
- 4,410
Are you having a defrost problem ?
