Page 4 of 4 FirstFirst 1234
Results 40 to 44 of 44
  1. #40
    Jun 2007
    Swamp Land U.S.A.
    I have a Briggs Storm Responder 5.5 KW, with my lighting load and a ice box running I start a 3-Ton Goodman GSX13036 All day long on my camp. The condenser has a kick start kit installed that is rated for up to 5Hp.
    I will get a video of it..
    I just put a Tri-Fuel kit on the generator so it will run on propane and methane. If the spent propane fuel does not take up to much displacement in the engine I think it still may run the A/C on the propane but not the methane.
    Gasoline
    1 gallon = 125,000 BTU
    Propane
    1 gallon = 91,500 BTU
    1 cubic foot = 2,500 BTU
    36.39 cubic feet = 1 gallon
    Natural Gas
    1 cubic foot = 1,050 BTU
    If I can't get the A/C unit running on the Alt Fuel I will put a larger engine on the generator frame to recover more HP when running on lower BTU fuels.
    It is safe and accepted by the NEC to run a generator with no transfer switch as long as a APPROVED inter-lock kit is installed at the panel the generator is feed into, we do this all day long and make good money at it. Every job is inspected by south central planning! just search for generator interlock kit "and hit I'M FEELING LUCKY" The kit is about $150 retail and $100 if you are a dealer for them.
    I have no ties to the above product other than I just use a lot of them for my customers!
    If you have a AutoTransfer switch your generator must provide the same amount of power your service from the PoCo provides, Otherwise you must have a load shedding system installed. All generac nexus and briggs smart switch provide load shedding provisions.
    All cables from your transfer device be it a switch or inter-locked panel must be oversized by 25%.
    Your generator does not need a ground rod located next to it as long as your EGC is sized properly for the ungrounded feeder conductors running from it.
    Guess I will stop now I could ramble about this for days!
    Sam
  2. #41
    Another 1+ year old zombiethread resurrected.
    RSES Certificate Member
    RSES-SWRA President
  3. #42
    Jun 2007
    Swamp Land U.S.A.
    Ha Ha, Must have been in the time machine last night! For what ever reason I looked at the date and still posted.
    Still some info that needs to be brought up as we have a lot of generator talk going on in south Louisiana right now!
    Sam
  4. #43
    Not only that, but an AOP Thread by a non AOP Pro.
    Samuel Rock, please check your e-mail as you have one coming soon.
  5. #44
    Mar 2009
    Mid-Mo
    That seems to be a full time job for you these days as da police.
