Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Apr 2008
    Upstate New York
    will my generator run my central ac ?
    I have a generator that is 5550 watt and peak 8550 it seems to run my whole hose when I need it, lights, refridge etc
    Is it ok to run my central ac ?? AC company said no problem.
    SE Michigan
    I would be real careful....many times the electrical sign wave isnt even and can damage circuitry.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    May 2009
    courtenay, bc, canada
    3.412 btu's per Watt
    Apr 2008
    Upstate New York
    Paci, what does that mean ??? Also, I have run my Rheem gas furnace on it and my refridgerators with no problems, isnt this what they are for ????
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by PacifiKool View Post
    So?
    What about the motor start-up draw?
    Jun 2007
    The Twilight Zone
    Quote Originally Posted by cvcman View Post
    My 3-ton heat pump draws 2930 watts steady-state at AHRI rating conditions for cooling mode.
    Not sure what the power spike is on compressor start-up. That may be a problem for your generator.
    Jul 2000
    Guayaquil, EC
    If you're already running lights and the refrigerator, a 5550 watt generator isn't capable of running even a small 2-ton central A/C. They simply don't have the surge power to start the compressor. They're pretty much maxed out with a 5-6000 Btu window unit.
    Here's a good read on selecting a standby generator to handle your A/C:
    http://www.generators.smps.us/sizing.html
    Apr 2008
    Upstate New York
    I think my ac unit is 1-1/2 ton ?? Its a small ranch house. I have 1 refridg. I have had this run my 80 gallon elect water heater before no problem ????
    How would I know for sure ?? If I tried it it would bog right down if it wasnt enough ?
    Apr 2008
    Upstate New York
    It ran my NG furnace ok , should it have ??
    Jan 2005
    Emerald Coast
    You're on thin ice ... Water Heater, probably it's a resistive load.
    NG Furnace, maybe - maybe not ... repair could be $$$.
    You need 12 - 15 kw to reliably run an a/c and there's no guarantee attached. You wreck it - you own it.
    Do not attempt vast projects with
    half vast experience and ideas.
    Apr 2008
    Upstate New York
    when I do the water heater I shut everything else off, the A/C chart beow said starting power needed fr 2 ton unit was 5k watts after 3 seconds that drops off a lot. Mine peaks or surges at over 8k watts !
    You dont think I should use it to run the furnace either ??? What the heck good is it then
    Bedford,Ohio
    What the heck good is it then?
    so you can fire up your puter and join us here.
    Apr 2008
    Upstate New York
    looking at the online sizing chart it says mine is PLEANTY big enought ot run my furnace and refridge and lights, you guys dont think so ?? Again it has 8550 surge ! I have run the furnace before on it with the refridge and small freezer with zero problems.
    If it couldnt handle the start wouldnt it throw the breaker on the generator ?
