Results 1 to 8 of 8
Thread: compressor unloading
04-01-2010, 07:01 PM #1
- Jan 2001
- 710
can someone explain what is actually happing inside compressor when compressor unloads. was working on large trane tin can. it had solenoid inside
cover.when compressor loaded suction went down amp draw up but never totally understood what happens intenally. i guess refrigerant is being bypasses internally. any tricks to troubleshoot/repair. anybody know of any good compressor schools.
04-01-2010, 07:06 PM #2
- Apr 2006
- mechanical room
- 1,212
whats the compressor type, model #, probably either the hot gas bypasses and dumps back into the suction side, or a piston blocks the suction not allowing the compressor to pump any refrig. thus not doing any work. thats about as simple as i can describe it
04-01-2010, 08:50 PM #3
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,514
It`s kinda like a Dodge MDS engine. When your in the city it uses half of it`s capacity let`s say it`s a 6 cylinder . 3 in the city and 6 on the highway.
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
04-01-2010, 09:07 PM #4
It depends screw most via slide valve, semi hermetic have a few different ways, Centrifugals by freq and turning vanes modulation etc...........
It takes courage to grow up and turn out to be who you really are.
- E.E. Cummings
04-03-2010, 10:32 PM #5
semis use either hot gas bypass which is inefficient or suction unloading
both can be operated mechanically, electric unloader, pneumatic unloader or oil pressure unloader.
i have not seen one but i have heard of some machines that LOAD when powered up????
i know that on trane E compressors that operate with oil pressure that they start UNLOADED
have fun
I WILL SELL WORK,GENERATE BUSINESS, GO GET NEW CUSTOMERS!
YOU SHUT THE HELL UP AND QUIT RUNNING YOUR MOUTH!
04-03-2010, 10:37 PM #6
http://www.hvacrinfo.com/ae_index.htm
Scroll down to section #21.
There you will find Copeland's AE bulletins on capacity control.
04-03-2010, 10:42 PM #7
04-04-2010, 01:41 PM #8
- Aug 2000
- USA
- 4,935
In a nutshell, the compressor is moving less volume of gas as it unloads. Be it by frequency, guide vanes, slide valve or rendering a few cylinders out of action. JMHO
Your poor planning does not constitute an emergency on my part!!!!
