Results 1 to 2 of 2
    Hi guys. Could anyone give me some knowledge how to change a water valve on a sub-zero side by side ref./freezer. do I need to pull out the unit to change the valve or there is a easier access way to the valve.
    Apr 2001
    Camel City, NC
    water valve
    If it's rear mounted, probably have to pull it. Can you reach it from under the front? Watch the floor if you pull it out. Good Luck
    Be safe not fast. body parts don't grow back
