Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
Thread: Ever see this?
    Jul 2009
    In a mechanical room....
    Ever see this?
    I had a pipe fitter adding butterfly valves on CW hydronic system, The pipe fitter used Teflon tape and Teflon dope and it still leaked it seemed to bead right out of the dope, He had them tight and clean what gives I am guessing the pipe is threaded too far back and it's bottomed out? Some real thick pipe dope/gasket maker fixed it but next time I would rather weld them up after all he used Victaulic after the nipples. This happened on all 8 fittings.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Gulfport, MS
    threads.
    did you back these fittings out completely and check the threads? i had a die set foul up on me once and didnt catch it untill about my 8th thread. ( you get zoned out with a hand threader! ) they could also be cut too deep as opposed to fouled up. giving the water a place to go.
    Virginia
    Since when is teflon tape supposed to be used along with dope?? I started seeing this about 20 years ago in the northeast. This contradicts what the union taught us. I have found that when using tape with dope it's not uncommon to have leaks....
    f its going in vic, why not use vic flanges?
    Jul 2009
    Quote Originally Posted by flange View Post
    Exactly but this was the pipe fitters job to figure out. I had not seen the job untill it was too late.
    - E.E. Cummings
    Baltimore, Maryland
    Quote Originally Posted by prorefco View Post
    I have to agree... sometimes too much dope is just as bad as no dope at all.... we have "Fitters" at my work making "dope sandwiches" Blue pipe dope. teflon, and more blue pipe dope..... I just laugh and pull out my PST (loctite 567)
    Virginia
    I have tried lots of different kinds of dope but I always came back to good old rectorseal #5 for most applications. All the others leaked at one time or another, either right away or within a year after application.
    I also have seen lots and lots of untrained fitters out there who have been working in the trade for decades... And when you attempt to correct their errors, they go off on you... Go figure.....
    Baltimore, Maryland
    Yeah I know what your talking about... they look at you like your some kind of idiot.... I use the rectorseal 5 on gas piping because it contains no teflon.
    i was gonna say rectorseal as well fridge side and plumbing, never had better results , that liquid teflon stuf is junk stan
    Keep it simple to keep it cool!
    Sep 2009
    Stumptown,USA
    For some applications rectorseal #2 I use #5 for everything else. I know it is old school but if I really don't want a leak and it is not potable water I use Permatex form a gasket #2 non hardening.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    Apr 2004
    I am a union pipefitter and plumber and I have put together miles of screw pipe and I will always teflon first and then put a little dope on.
    Baltimore, Maryland
    Quote Originally Posted by hvacplumb View Post
    What local are you out of? I'm a Union Fitter too, I don't see the need for teflon and dope. Some guys, I see using teflon, put too much on causing the teflon to just push up the threads..... Do you use teflon on your gas piping?
    Nov 2008
    Long Island NY
    rope it and dope it
