Results 14 to 26 of 26
    Nov 2008
    Altamont, IL
    I've got 2 that I need to convert to the solenoid's How do I get the software for the CPCC. ??
    In GOD We Trust
    Mar 2010
    Perkasie, Pa
    Cpc can mostly connect and update for you, you just the new board points and what not. Anyone correct me if I'm wrong, it's Friday and I'm a few beers deep
    Nov 2008
    Altamont, IL
    There are no phone modems or web modems.
    In GOD We Trust
    Dec 2006
    In a Mess
    Quote Originally Posted by Dowadudda View Post
    that is a very common mistake of techs who are not familiar with the system.
    Or how about the, reciever has lots so I don't know why the cases are starving!! haha
    Sig removed by mod. G-Rated site
    Jun 2001
    Michigan
    Quote Originally Posted by MikeySq View Post
    yep. No condenser will do that every time.
    Jun 2001
    Michigan
    can a guy go in and chop up a rack that doesn't have this and do it? Is that breaking the law?
    Jun 2001
    Michigan
    Quote Originally Posted by jdwendling View Post
    I may have missed it but. Why do you want to go to gen3. Are your SPR's shot?
    A lot of guys think these are bad when they are not. Guys will go in and screw with these things and get them so far out of whack that you might think it's bad and it's really not. These systems get misdiagnosed a lot. It's usually the know it all types who think they know what they are doing.
    In GEN3, one has to do 2 solenoids. If you got gen2 right now just rip out the SPR and keep the solenoid that is there. GEN2 is a NO solenoid and you will need a NC for GEN3, but that is okay cause you can reverse the logic in CPC for the function of removing the refrigerant from circulation to the receiver. Just understand why gen2 had the NO, close on fall of ambient. and in Gen 3 you have a NC, opens on a rise of sub cooling.
    The 2nd solenoid needed is the one that will dump to suction from the top of the reciever. This is actually the 3rd solenoid. Remember we will always have the bleed solenoid continously returning refrigerant from receiver to suction through a superheater and cap tube as long as one or more pumps are running.
    This 3rd off the top of the receiver is to induce flow from drop leg when refrigerant needs to be removed from circulation.
    It's set for a 5 minute delay. So if your calling for your sub cooling solenoid to begin to remove liquid from circulation (opens on a rise of sub cooling) based on conditions set point, and after 5 minutes if it's not met set point this 3rd solenoid actuates. Takes gas off the top of the receiver and dumps to suction. This reduces receiver pressure and allows the sub cooling solenoid drop leg liquid to flow into the receiver.
    This induction of flow is needed when conditions are just right. This can happen when the drop legs refrigerant is at a lower saturated condition than that of the receiver in a cozy warm machine room. Fall/Spring & Dead of Winter.
    Now. Going to GEN3 in Reflecs sucks tit. It can be doen but it's harder for techs to understand what the heck is going on. In the e2, a guy can set up a conversion cell screen and you can see the entire operation and all the calculations in one convenient application.
    Nov 2008
    Altamont, IL
    Especially in the spring and fall when we have such varienig ambient temps it seems to dump too much liquid into the receiver and it takes too long to get it back into the system when it is needed.
    In GOD We Trust
    Jun 2001
    Michigan
    if it's not set up just right it will do that. But. If it's set up correctly and on the nut, it will not do that.
    Cedar Rapids, IA
    I'm about a 5 hr drive from you. I have the software, laptop, and I have converted racks before. What version of software does the CPC controller have?
    Quote Originally Posted by bob_scheel View Post
    Is there a way to update the software on the reflecs controller with ultrasite?
    florida
    Quote Originally Posted by mjm88 View Post
    Reflecs are a thing of the past. It would be like looking for an up date for a IPC.
    Educational forums are open.
    Quote Originally Posted by crackertech View Post
    Well I have a system I'm trying to program on a press2temp sensor for and it's not available on the version of reflecs. I didn't know if I could update it to get that feature
