Results 1 to 13 of 13
Thread: LOBSTER TANKS
    Jan 2002
    Working on a existing lobster tanl in a resturant,the copper to plastic tubing joint keeps leaking,I repaced the
    3/8" compression joint, but it still leaks. Any one have any good ideas? The unit is using "hot shot"
    Apr 2001
    Camel City, NC
    3/8 compression
    Did you put the metal sleeve inside the plastic tubing for support?
    Be safe not fast. body parts don't grow back
    Windsor, ON Canada
    I didn't think you could use compression fittings of refreigeration.
    Apr 2001
    Camel City, NC
    compression
    I thought he was on the water side.
    Jan 2002
    lobster tanks
    The compression fitting was "factory" but it leaks there, I replaced the compression fitting with a new one,and can't get a good leak proof joint,it is tough getting the farrel over the plastic I think it may have swelled with time. They use a plastic evaporator coil in the water because lobsters can't stand any exposure to copper it kills them.
    Apr 2001
    Camel City, NC
    Tom
    If using an insert doesn't help I'm of no help here. Only seen 1 tank in my life.
    Can you cut back of piece of the plastic, and restart the compression fitting? just curious.
    Jan 2002
    I tried that, but it didn't work and the plastic tubing appears to have swollen with age, I see no manufacture's tag, I'd like to see if i could get a new evaporator or see they might have a fix, it must happen elsewhere at times.
    Tom
    Apr 2001
    Camel City, NC
    Try This Tom
    Jun 2002
    New Jersey
    I ran Into the same problem about a year ago. i replaced the tubing, nut and ferule with air brake tubing and fittings that you should be able to get at any good auto parts store. so far over a year and no leaks. let us know how you make out
    Not to my suprise you have a leak the tanks anyone is producing are just not rite.They should be some kind of chilled water systemkinda likr the amana rooftops that had thenhot water coil
    Port Hueneme, CA
    Marineland most likly made it. We do not use the plastic tubing any more. We now use coated copper coils.
    northern colorado
    Comming out of left field is..
    If your tank has a water pump system go get a water condenser, reverce it, and put a TXV.
    If your system has been serviced, with hot shot, you could has some acid in your system that will melt the plastic evap.
    Create a chiller for the tank, and you will be much happier.
