Results 1 to 13 of 15
    Chicagoland
    True prep table..What is it?
    This is a vague question, I know.
    What is the devise in the suction line after the evaporator? Seems to be hung like an accumulator. Has its own little drain pan and line.
    st.petersburg,fl
    Lightbulb
    Its an accumulator...
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
    Chicagoland
    Thanks, I figured as much but wanted to be sure it wasn't a filter of some kind. The accumulators I see are generally a little bigger.
    st.petersburg,fl
    anytime
    Jan 2010
    Had one split at the seam on the bottom once.
    Chicagoland
    This one is leaking at the inlet (in the braze) and at the outlet on the pipe about 1/16" away from the joint. Knowing what it is for certain Ill try to fix it rather than replace it.
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by AccurateHT View Post
    A word of caution...
    Be aware that these little accumulators often contain a significant amount of oil. I suggest cutting it out and flush it out with a solvent like brake cleaner first. Then you can do a clean repair and re-install.
    Also, it'll be a lot easier to work on if you remove the cabinet top. There are a several long screws in the top of each door frame to remove then cut the sealant all the way around. There's a hinge-like lip across the back, so just lift the top front and push back to release it.
    Chicagoland
    Sounds like great advise, thanks.
    Jan 2010
    Quote Originally Posted by icemeister View Post
    Ice,
    Are you saying the whole top of the prep cooler like including the front cutting board area ? I have never done this. Would make it a lot easier to access. I usually just remove the alum skin covering the evaporator. That sealant can be a real bugger. I cut suction line in the back & cut cap tube @ strainer. Then pull coil out.
    Jul 2000
    Guayaquil, EC
    Ice,
    Yes, for True sandwich preps and pizza tables the entire top comes off quite easily once you've cut the sealant. I use a sturdy, wide-bladed putty knife and tap it along with a rubber mallet. You should have it off in 15 minutes or less.
    FWIW the bar cooler tops come off like that too
    Jul 2000
    Guayaquil, EC
    Agreed, there are many True models whose tops are removed similarly.
    You can find specific instructions in the True Service Manual. Just check the index listings.
    cyberspace, FL.
    Red face icemeister.....
    I'm gonna stop by and buy You lunch someday................You are awesome!
    Arcadia is about as far east as I work but a day trip is overdue, I'm buying!
