Page 9 of 10 FirstFirst ... 2345678910 LastLast
Results 105 to 117 of 120
  1. #105
    May 2008
    north east PA
    Have over 50 installed at different sites all work flawlessly and yes they talk sedona modbus and bacnet all at the same time the new ones due out will have its own html5 graphics engine and it own workbench that will no longer have to have ax workbench
  2. #106
    Jul 2010
    Denver, CO
    Quote Originally Posted by dlhvac View Post
    Do you have any information, brochures or spec sheets, on these new controllers. I just got into the EasyIO system and have been asking around about these controllers but just keep hearing that they are going to be awesome without any "proof". I am just curious about them. So far, I do like the EasyIO controllers and Sedona is pretty sweet. Programming is a breeze and integration is very simple too.
  3. #107
    May 2008
    north east PA
    Quote Originally Posted by HuNGRYTeCH View Post
    THE CONTROLLERS WILL BE OUT AT THE SHOW IN DALLAS IM BETA TESTING A PROTOTYPE
  4. #108
    Amarillo by mornin'
    What SHOW are you referring to?
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
  5. #109
    May 2008
    north east PA
    Quote Originally Posted by xarralu View Post
    the ashrae show
  6. #110
    May 2008
    north east PA
    the ashrae show sent you an email
  7. #111
    Amarillo by mornin'
    Awesome! Thanks for the info I appreciate it.
  8. #112
    SE Pennsylvania
    What is the lowest cycles per second the 30P should running. I have one that I may just be asking too much from, running 4-5 cps in the benchmark.
  9. #113
    Jul 2010
    Denver, CO
    Quote Originally Posted by hvac69 View Post
    I've been told a minimum of 7 cycles and thats pushing it. Below that its going to freeze or crash. You can probably free up some room by dividing your program up into more folders, that seems to help a little bit. What all are you doing to be running that low?
  10. #114
    SE Pennsylvania
    Two loops for valves, 2 separate 2 pump lead lag based off max run time with failure changeover, manual reset and notification, alarm for high and low limit and sensor failures, boiler staging with rotating first on. Only using Sedona network. I will try to split it into a couple more folders.
  11. #115
    Jun 2006
    Does anyone know what these new FG controllers will cost?
  12. #116
    May 2008
    There is also a V2 Easyio30P that has a better processor and more memory; it can easily recognised by a blue run light instead of green.
    My experience is that using the modbus comms on the controller tends to use a fair amount of cycles.
    1 program I have written maxed out a V1 and is down to about 8-9 cycles on a V2; when I have the time it will be rewritten smarter and more efficiently.
    Dazza
  13. #117
    Dec 2011
    Charlotte, NC
    Assuming that the EasyIO FG controllers you mentioned are what they are referring to as "The Beast", they are supposed to be about 30% more than the 30Ps. Last I heard was that they are supposed to be released at ASHRAE.
