    I'm not a big fan of tearing apart res refridgerators but I have a small puddle of water right below the freezer door that has ice and water despenser. I also have a bit of ice buildup on bottom of freezer compartment. I would appreciate Any suggestions I think it might be a pinhole leak in the waterline going into the door. But i still don't understand what would cause the ice on the bottom of the freezer compartment. the puddle on the floor is just enough to use up one paper towel a day.
    It may be your frozen food compartment drain line blocked. Maybe.
    Go to library and find a book on servicing these systems. Should prove to be very rewarding.
    you might check to see if water is leaking from the icemaker
    which would explain water in the bottom of the freezer someone may have broken something by craming food in the freezer
