Results 27 to 39 of 41
  1. #27
    wow!!!!!!!!!!!!!!!!!!1
    i am not a blue oval fan!
    that being said!
    I have dozens of 30 series chillers.
    30rb, gxr 30 anything?
    screws, recips and scrolls.
    I really have not had many problems????
    Maybe this one was built on a friday??
  2. #28
    uk
    It looks as if the fan motor may be twisting trying to overcome static pressure. The photo showing the fan sections is that some sort of enclosure around the top of the unit.
  3. #29
    no they do not have enclosures. they look pretty new, looks like nicro channel cond coils!!
    Most likely ICE!!!
    lots of ICE! lol
    Quote Originally Posted by Gibbo View Post
  4. #30
    uk
    If you look at the 2nd last photograph there is clearly some sort of enclosure behind the fan cowlings.
  5. #31
    still not eein it???????????
  6. #32
    chucks of ice/snow causing problem.
  7. #33
    Central Indiana
    Frown condensor motors
    Has any one experienced condensor fan motor failures on these 30rba units? We have a 250 and a 125 and have lost about 12 motors. Failure mode is always bearing failure which then causes rotor to stator grounding. Motors cannot be greased and have no thrust bearings. Any replys would be helpfull.
    Thanks. Mike
  8. #34
    Austin, TX
    I feel that if I have to replace 2 fan motors, 3 sensors, and a plastic fan blade in one year on a 5 year old unit it is a piece of junk. Which is what I usually find on Carrier Air cooled chillers. Not to mention having to have a 10 page error code dictionary to find out what T331 means. Can't the screen just say Liquid line sensor failure.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
  9. #35
    Show me state
    Wow
    This is an old one.
    I saw noone had responded to you but After 7 years with this 30RB and 10 motors I have the same issue. I lost 4 this summer and the shafts are sloppy not just a little either.
    Did you ever happen to get an answer?
    A friend of mine that works for Carrier says that this isnt an issue that he is aware of but it sure is for me and not just this chiller. We have 2 others. All I can think is the blades
    Just curious if you had heard any more or figured out a remedy.
  10. #36
    Central Indiana
    We called in a motor rebuild specialist. The bearings were the failure. All the grease was out of the bearing. We now buy a new condenser fan motor and send it to be rebuilt with sealed bearings. $800 for the motor $100 for the rebuild. We are now doing this to see how it works out.
  11. #37
    Show me state
    Thanks for the reply,
    Wow that is pretty extreme. I was hoping to hear something a little better.
    If that seems to be working I guess thats my next option. I am going to try to start a new post to see if I can get any responses as well. I cant believe we are the only 2 having issues.
  12. #38
    Plattsburgh NY
    I have 2 30GX screw chillers and yes the fan motors go very often. At least 2 every summer on each chiller. Look at the size of the fan blade, its huge and i doubt balanced very well. Those blades chew up those motors.
    What do you mean you can't compress liquid!
  13. #39
    Atoka, TN
    Many upgrades on the 30XA, RB, and RAP machines. Check you fan propellers if you see them turning white change them out.
