I have four sets of gauges and the way I check my gauges is I got a Trojan tee coupler that I can attach two or three set at once and if they all read the same I know the gauges are pretty accurate. If they are not then I either calibrate them or trash them but one thing I do every year is buy a new set of 72 in hoses.
Heat in the Amazon
This is a fascinating discussion so far.
Hey cockroach, don't bug me! ©
I still have one set of gages and they are accurate enough. I been thinking about purchasing another. What about the CPS brand gage? I like it. Does anyone recommended or not recommend it?
Thanks.
On the edge of my seat
I can't wait for the next reply.
I would not want to keep you waiting Dice.
Besides normal manifold sets, a market man should at least have one dual high gauge set. It sure helps when checking your defrost differential.
As Dave has already mentioned a dual low and a dual high are a good idea.
I keep a hose with a depressor on my low side only. My common and high have none.
But my high side does have a CA1 manual depressing valve. This helps on smaller systems. I just back off the depressor and pump all the liquid into the suction side.
Plus I just don't like frozen fingers.
You go girl.
I'm gonna spring for the digital set soon.
I'll order them thru WalMart so if I dont like em, I can take em back and get my money back.
(24 sets of gages .... sheesh!)
And I want more.
Calibrate Gauges
The best way to calibrate gauges is to hook to a drum of r-22 (or whatever you have handy) that has been stored in a controlled ambient temperature for several hours. then calibrate gaug to pressure -temperature chart. this will never lie as long as you use virgin refrigerant.
And I want more.
OH .... and I guess you got a special one just for measuring oil pressure at the pump scraeder?!?!?!
And I want more.
As a matter of fact, I do.
I think some of you have a gage fetish.
Sick.
yea......snap-it hard baby,
Don't interrupt me while i'm talking to myself
- You may not post replies
- You may not edit your posts
Forum Rules
