Results 14 to 22 of 22
    Guess we've always just replaced the valve when it comes to impact cases flooding, never gave much thought to the stem kit. Have to check with the local wholesalers and see if they are stocking them. I believe those valves are OEM are the stem kits or are they the same as other sporlan valves? We always refer to the Hussmann valve replacement chart that shows suitable adjustable replacement.
    Had an entire lineup of LWU's that were flooding on startup when Impact first came out, Hussmann airmailed the stem kits to install on every valve, since then only seen the occassional impact valve do the same.
    Watts New, Ohm My, I been Electrically Commutated. Are U2.
    Earth
    Hussman philosophy; lets use the worse valve we can, and then put three in every case.
    Apr 2002
    Dallas, TX
    The Sporlan BI-series TEV used on the Hussmann impact cases use a KA-I/BI bottom adjustment kit.
    Sep 2001
    East Stroudsburg, PA
    I only saw that problem for awhile about four years ago, or so, then it stopped.
    Changing the valve guts always corrected it. That and tightening the stinking BULBS.
    Were the valves redesigned, or was the application corrected, or something, Andy?
    Jul 2001
    Gold Coast of Connecticut
    I think the cause was the valves getting everheated on install causing the spring to squish ....................thats what i have found with them.
    Jul 2001
    I PERSONALLY changed 350 of those damn valves..made OT 2 or 3 nights a week for monthes.
    Guess I'll have to get some of them. Thx.
    Apr 2002
    Dallas, TX
    The newer non-adjustable valves are simply holding tighter setting tolerances. That and determining the correct settings has no doubt improved things.
    Nov 2003
    Yea, I'd quit if I had to do that too. I changed three in one day and my lungs hurt for a couple days. (Store remodel but same leaky ball valves at rack)
